Question about Pioneer Car Audio & Video
I have the older style 760 pioneer amp black and silver with the blue light. The amp worked fine a couple days ago but then it just stopped working. The blue light flashes. i redid my ground and it didnt help. But if i hook my remote to a direct power source the light stays on.. But the amp still doesnt work
  • 356 Answers
It sounds like the power supply capacitors have failed.
Posted on Jan 01, 2018
  • 119 Answers
SOURCE: Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Posted on Nov 04, 2006
  • 10 Answers
SOURCE: Amp just abruptly stopped working (Pioneer GM-5300T)
Apart from the external DC power fuse (I hope you have one in-line), the majority of in-car amps have 2 mini fuses inside the unit to protect the output MOSFETs from overloading due to incorrect speaker connections, ie, if the output impedence is rated at 4ohms, anything less than that is considered to be a short circuit, and will overload the MOSFETs. After performing the tests suggested by KaeZoo, open the unit and look for printed markings on the circuit board, something like F1, F2, the fuses may not look like conventional fuses.
Posted on Jun 12, 2007
SOURCE: Pioneer GM-7300M 800 Watt amp will not power on
chenge the fairroll,and reset your sistem go
Posted on Aug 24, 2007
tech48
  • 624 Answers
SOURCE: Pioneer 760W (Mosfet Power Supply) Amplier
If you are connecting the negative lead of the voltmeter to the chassis of the car, and then checking the voltage at the amp on the ground power input of the amplifier, then your amplifier is not grounded properly. The amp should also be grounded on the chassis of the car, so if you have 4 V DC on it, it can not possibly be grounded to the chassis. The chassis is the same potential at any point on the car.
Could it be that the 4 V DC is at the power terminals +B or positive voltage? That would not be an uncommon thing to have since the amplifier will hold some charge after it is turned off and that would be normal.
Since you have a voltage meter, you could check the current draw of the amplifier if your meter also have a setting for current or amps.
If so, connect the meter in series with the ground of the amplifier. That means to disconnect the ground wire at the amplifier, and use the meter to complete the ground connection by putting one lead of the meter on the ground wire that should be connected to the chassis of the car and the other lead to the ground terminal of the amplifier. It does not matter which lead you connect to the wire or the amplifier, that would only make your measurement i postive current or negative current, but the meter must be set up properly for current. Most of them have a diiferent jack to put the positive lead into for current. most have two different jacks. If yours does also, choose the lead with the larger amp rating. Most have 10A and 300mA, the lareger amp rating is 10A. That is 10 amps max and the 300mA means 300 milli-amps which is .3 amps max.
Do this with the amplifier turned off and the car off. If you measure any current at that point you do have a current draw with the amp off and the amp would need to be serviced by a professional. If you have no current draw there, the amp is not the source of your battery draining. This would find out for certain if the amplifier is really draining the battery.
If you have found this information help a rating of "FixYa" would be appreciated.
If you need more help just ask,
Dave
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: mosfet 760 watt pioneer amplifier
Check all ground cables from your truck's stereo and amplifier as well. Sometimes when ground cables get loose you hear those thumping noise in your subs. GOOD LUCK!!
Posted on Nov 06, 2008
Channel A wont work
check to see if the signal to the amp is low pass and check to see if the switch is on high pass.. if all checks out send the amp back .. if u want to repair it email me at steven007_maharaj@hotmail.com and i would tell u how
Jun 14, 2013 | Pioneer GM6500F 760 Watt 4 Channel...
Pioneer DV-400V. Worked fine a few hours ago and
Mine did the same a couple of days ago, I have taken in for repair, will get back once with details soon.
Sep 30, 2009 | Pioneer DV-400V DVD Player
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a pioneer avic-ni in dash dvd/navigation system. Two days ago the display screen stopped working totally black & it will not eject the current cd
Common failure on these units is the flex cable. Contact Pioneer and send it to them for service. Last I heard they were not suppling this part.
Aug 29, 2009 | Pioneer AVIC-N1 Car DVD Player
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car Audio & Video Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
