Question about Cameras
Does not take a charge from my pc I leave it pluigged in overnight.
  • 6,826 Answers
If it doesn't take a charge overnight, the batteries are likely spent, unfortunately.
Try new batteries.
Posted on Jul 21, 2010
Powerex MH-C204W charger. Recommends leaving them on the charger overnight for the first charge. I was told at the store the charger automatically turns off when charging is complete. ???
Where is the problem ? Leave to charge overnight, charger turns off when complete. The two are complementary, not mutually exclusive.
Jan 11, 2017 | Cameras
Left key on for few days battery dead I jumped it off and runs very rough when give it gas gauges go out and backfires
Hi Did you leave the jumper battery hooked up while it was running? It sounds like the dead battery may need to be replaced. Jump it again and leave the jumper battery hooked up and then see if it runs ok. If it does run good you will need to replace the battery. I hope this helps. Rod
Aug 14, 2015 | 2004 Suzuki VL 1500 Intruder LC
I left my hp4320s probook charging overnight now it will not even go on
I think leaving your computer charging overnight is not really bad. I think there is a fault, in the power hardware of the pc.
You should see a technician..
Again, be sure that the charger is still working properly or try getting a new charger and putting on the computer, without a charger.
Apr 17, 2014 | HEWLETT-PACKARD Computers & Internet
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
Samsung troubleshooting
it is charger problem or the battery is old -poor-
Nov 29, 2013 | Samsung Galaxy Tab Tablet PC
Laptop not responding to AC jack being pluigged in so cannot charge laptop
Hi Geraldine,
Lets do some basic trouble shooting steps to find out whats going wrong with your computer.
It can be either your adapter or the charging port(where you plug in the adapter to the computer) or the whole computer itself.
Try connecting the adapter to some other laptop and check whether it works or you can try some other adapter on this laptop and check.
By that way you can determine whether it is the adapter or the laptop.
Also if it is the adapter, you have get a new one.
And if it is the laptop, it needs to be repaired.
Dec 04, 2011 | Computers & Internet
Basically when i charge my laptop it wont turn on and the lights dont flash either i have tried checking the charger on another eee pc 4g laptop and worked i also tried swapping batteries but still...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
Then, un-plug the charger, an pluig-in the battery, try turn the laptop on.
Please tell us your results
Good Luck
May 15, 2011 | ASUS Eee 4G Notebook
My EI Systems laptopwill charge the battery when on ac power but when i unplug from the mains it switchs off even though there is charge in the batteries
try leaving on overnight
to charge battery
else may need new ac charger
I know hp chargers only last 2 years of hard use
cheers
Sep 16, 2010 | Computers & Internet
Batter won't hold it's charge if left in the camera overnight
Apparently you shouldn't leave the battery in the camera when you're not using it - the on/off switch doesn't turn the thing off completely. Weird!
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
