Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Brush is not turning, where can I take it for service. Zip code 37075
    Genius:
  • 1,970 Answers
Mcdevito75 here, You should be good at any appliance repair shop in your area, ask around.
Posted on Jul 21, 2010
My Kirby zip brush will not spin. I cannot take it apart, any hints?
No bearing inside only brass pivot, zip brush turbines get jammed because of hair getting trapped between the two blades, simply remove top holding plastic cap, it come into 4 pieces. lay out in order cut hair off spline and re assemble
Jul 13, 2016 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
It won't spray water out of the floor cleaner but it will out of the upholstery cleaner.
If your machine is spraying through the hose but not to the floor, check to ensure the spray tips at the base near the brush roller are clear. Using a pin or safety pin, **** the spray tips or use a cloth to clean.
You can also try these troubleshooting tips:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Apr 20, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
The big brush is not turning anymore.
All kids of brush are having same problem. They get stuck after a few times used. If you have a user manual, please check the section where it is explained how to maintain your product. Cleaning your brush can be done easily, depends on the model. Use a dusting brush & crevice tool to vacuum clean the brush and fan it well. Check for any material parts who can get under the rotative brush and untangle.
If this is not helping, plese find an authorised service center, depends on the producer it might cost or not for serviceing accesories.
Apr 11, 2011 | Vacuums
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Loses power & smells like burning. I'm worried the motor is burnt up. the belt looks fine.
If the belts are intact and the brush roller is rotating and the problem persists, the machine should be inspected internally at an authorized Service Center. Go to www.bissell.com under the Customer Support tab and enter your zip code under Service Center search.
Jul 04, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
On my Dysen DC 24 Ball the ball is not rolling easily and the brush feature is not working. Is there a repair center near the 94941 zip code?
this modle not easy replair if unit have warranty you send service for free.
Bestbuy store
MARIN CITY CA (Store 132)
180 DONAHUE ST
MARIN CITY, CA 94965
Phone: 415-332-6529
Hours: Mon-Sat 10:00am-10:00pm
Sun 10:00am-7:00pm
Nov 04, 2009 | Vacuums
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
66 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
