Question about Fantom Drives 120 GB Hard Drive
All of a sudden my computer dosent recognise the USB Drive ( PQI - U230 )
It used to work fine, but now my PC is not able to identify the USB Drive. !!
I already have some important files on it.
Any help would be much appreciated.
Thanks
  • 1 more comment
  • Diggerdog22 Apr 22, 2008
    same problem, except mine says the drive is not formated
  • marc S May 14, 2008
    For the last year I have backed up my personal and corporate data to my Western Digital my book essential edition 500 GB Harddrive. My motherboard failed on my HP Laptop. This forced me to buy a new computer from Dell and restore my data. While I was recovering my data when my Western Digital HDD refused me access.Now my computer does not let me access it. I get an error mesage which tells me to format the drive. If I do this I will lose everything I own because I have forwarded all my information to this drive from past computers including all my family photos. There must be a better solution for this problem because I have read many stories with the same problem. I called western Digital tech support but they would not help me. They claimed my unit was out of warrentee. It was not and I faxed them the store receipt and waited two days for them to call me back as they said they would do.
    NO JOY, it is very unsettling to have your entire life wiped away. I backed up all my data like a good user but how would I know my backup would fall too.
  • Anonymous Dec 18, 2008
    NOT WORKING WITH ANYTHING
    Scholar:
  • 170 Answers
At this point i would take the usb drive apart, you should see a regular hard drive in it. if so just set your jumper settings and insert it to your computer. if you still got problems then your drive has crashes on you. you can try at this point some hard drive recovery tools found across the net.
if the drive is too small to plug in then you need to get an adapter usually found at ebay. if this is a pen drive then i would take it out of the case then look for and solder the usb connector as this is the first bad spot to go. anyways, if its a hard drive and works in computer, i would check power supply goin to the use drive, if its good then i would contact the company that made it maybe they will replace the unit. or just buy another one. copy info back over to the new drive. or get a drive just like it and swap them out.
good luck.
Posted on Apr 24, 2008
My problem and my solution
-Fantom Drives 200GB was working correct on desktop which runs Windows XP
-Connected it to a laptop which runs Vista and the drive became undecteable by both platforms. It showed up on Vista's device manager for a hot second and then vanished all together.
-Changed the USB cable and still no go
-Finally, I made the decision to void the warranty by opening it and connecting it directly to my CPU and there it all was. 170GB worth of data. Same as what scott201201 is suggesting above.
-Moral of this story...."Backup your "backup".
Good luck techies
Posted on Dec 02, 2008
  • 979 Answers
If you are running XP or vista, then go to your device mgr and be sure that the USB port is powered on and enabled. Hope this helps...accordianman
Posted on Apr 23, 2008
    Genius:
  • 2,785 Answers
Plz check your usb drive is working(led will be glowing),if yes then plz scan your pc in safe mode with updated viruses definition and disabling system restore.
Win 7 detects PQI USB flash drive 8GB but not successfully installed due to no driver found
It is probably faulty in that case if other USB items work in the same port.
Sep 30, 2017 | Computers & Internet
I have a USB Flash Drive by pgi. It is 8 GB, silver color. When i plug it into my laptop(Gateway, Windows 7, Intel Core i3-370M processor), it doesnt read it and in the Device Manager I get the following...
Try the flash drive on another computer to see if the problem is the drive itself. The drivers for a USB flash drive are built-in on Windows 7, so the problem is NOT that the drivers aren't loaded. The problem is almost certainly that Windows is not correctly identifying the device, which is almost always a problem with the device itself.
If the drive does work in another computer, be sure that it is formatted and put a couple of files on it and make sure that the computer can read those files - then try the flash drive on your laptop again.
If this flash drive works on another computer and still doesn't work on your laptop, try another flash drive on your laptop. If the other flash drive gives the same error, then you will probably need to repair your Windows installation - which is a job best handled by someone with more experience unless you are willing to risk whatever else you have on the laptop by just doing a full reinstall of Windows.
Dec 05, 2017 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
My PQI usb flash drive is not recognized by win7.
http://www.pqi.com.tw/upload/download/Fixer%20v1.0.0.2.zip use this on xp
Jan 13, 2011 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
MY pqi 4gb travelling disk is not working actually it is not getting connect with PC.Any hardware problem?
if you already tried different computers, and checked if the USB port is a known good port, then it might be your USB flash drive thats having problems. Check if your flash drive has lifetime warranty thru PQi's website...you might be able to get that 1 replaced..
Hope it helps..
Feb 15, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
EXTERNAL OPTICAL MOUSE IS NOT RECOGNISED BY LAPTOP
1> Click on start and then run or press( windows key+R) and type devmgmt.msc and then expand the item Mice and other pointing devices, right click on ps2 compatible mouse or the item for the mouse.
2> On the Power Management tab, change the power management settings.
Jan 10, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
Hi there, I have a MyBook essential edition 500GB and its not being recognised by my laptop when i plug it into the USB. What do i do? I've used it before and its worked fine
Try a friends computer. If that dosent work, check the ac adapter, replace is nessary. if that dosent work put the hdd in a nother enclosure, still not working, the hdd istelf will be broken, tae the drive to a data recovery centre
Aug 01, 2009 | Western Digital My Book Essential Edition...
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
I have problem with reading my PQI 1GB Mini I-Stick i810 2.0 USB Flash Drive.Computer doesn?t read it at all. Can?t recognise a new drive. Please help
If you are using Windows XP, please check if you have install service pack 2 or later,
or check if proper driver is installed..
Mar 26, 2009 | Computers & Internet
Pqi travelling disk(1gb)U230
Download and install Partition Wizard on your computer.
Put the USB in, and open up Partition Wizard. Click on the 1GB drive, now on the left side click format. On the top left click Apply and wait. once done your USB is formatted and open. Hope this helps.
Dec 05, 2017 | Electronics - Others
Fantom Drives 120 GB Hard Drive Logo
568 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
