Question about Emulex (DCP-CAB-4-01) Parallel / Serial Adapter
We have old dos base machine emulex dcp88 card fixed for commmuncation now it was faulty you have any solution card type assy pt1010458-04-rev-j it was communicate between plc to pc
Ir c3200 is offline
Check that network settings are still correct in system settings. If they are then power down the machine for 10 seconds and restart it. Wait for 10 minutes to see if it comes online. Try pinging it from a pc on the network to see if it can be seen - to help determine if there is a faulty network card in the machine. Pinging means entering the DOS screen and typing 'PING (SPACE) 'IP ADDRESS OF MACHINE' then enter.
You should get some response if it's connected ending with a number like TTL225 etc. Check that there are no error messages on the machine itself causing it to force itself offline.
Nov 09, 2009 | Canon imageRUNNER C3200 Copier
Dishwasher has fault code ie
IE fault indicates water fill problem. Check inlet hose not kinked or blocked. Check no water in base activated flood switch. Otherwise, problem will be a faulty inlet valve(can test with Ohm meter), faulty flow meter (measures water intake- cannot test with meter), or faulty control board. Flow meter located on Left hand side of machine- accessed by removing side panel. It has a sensor with 3 wires(red,white,black) which goes up to control board. If inlet valve tests OK (about 4K ohms), and there is no water in base, I would try replacing flow meter assy (comes with housing and sensor complete)
Aug 08, 2009 | LG Dishwashers
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
Beeps On Boot
Sounds like it could either be a video card error or the bios rom chip is faulty, first try to rplace the video card, if you still have the error, replacec the cmos battery or at the least take it off the mother board and leave the computer unplugged for about 10 minutes, then replace and start again, failing that the motherboard might be faulty which would have to be replaced.
also try different memory chips, although the code you describe doesn't pertain to ram error it may be the cause
Dec 11, 2008 | Computers & Internet
Cannot connect to internet.ethernet connection does not click into router.cable is not faulty
can u go to control panel>network connections
and see if u have got any network connections? usually it will be something called LAN or something u have renamed it as.if a network connection cannot be found it means ur having a problem with your network card driver which is in the motherboard CD if the card is on board and a separate cd if the card is pci. or if u have the network connection open up startmenu>run> and type cmd and press enter. in the dos command prompt u can type netsh winsock reset
and reboot the system. that might also fix the issue.
Nov 30, 2008 | Computers & Internet
Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Aug 17, 2008 | Emulex NetJet (NJ01B-NTplus) Print Server
Cannot install a sound card
use a USB ,mouse and try the same
Jun 16, 2008 | ASUS P4P800-MX Motherboard
Changing the IP address
check with the manual of the server that it is having web based management. If yes make your computer ip and subnet mask as per the ip and subnet mask of print server. open the internet explorer type the url as specified in manual enter the username & password as per manual. there will be the setting page displayed where you van change th eip of the print server. if not please write me which type of management it uses to access the settings.
May 10, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Computers & Internet Logo
63 people viewed this question
Top Emulex Computers & Internet Experts
David Payne
David Payne
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
