Just bought SAMSUNG HT X200R HTK home cinema system and I can not get the sound to work through the tv, it does however work through the DVD, can you help?
There are so many things to be consindered 1.does your tv sound comes out from the speaker without connecting the DVD
2.If the speakers from the tv ok,check the av line on the chassis of your tv set/check the av cables
Posted on May 05, 2008
I cannot get surround sound to work when watching normal tv or sky,i have a samung tv and samsung home cinema system.how can i correct this
cant get surround sound through tv but works on dvd???
do ineed a component cable from dvd to tv?
tv= samsung le40c530
dvd= samsung ah68-0041oy
Feb 05, 2010 | Samsung HT-Q100 System
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
-samsung dvd cinema surrond system ht-x715t htk makes loud buzing sound when switched on. - need a code to programme sky remote control for samsung lcd tv le40a656a
good day
try looking for loose connections in your speaker cable as well as its connection through its terminals, there might be some loose connection somewhere which causes some grounding on your system. you can also try to reattach your speaker system.
i hope this helps
Oct 09, 2008 | Samsung Televison & Video
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Samsung HT-X200R Cinema
According to other internet sources, this device does not allow you to adjust the bass or tremble. Very disappointing Samsung.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
