Question about Tally Line Matrix T6215 Printer
Shuttle Fault on display screen
Shuttle Fault on display scree. Model Tally T6215
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
If you want technical support of Xerox, you can contact us on Xerox Printer Customer Service 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/NBL7U4
Posted on Aug 08, 2017
    New Friend:
  • 24 Answers
Do you need tech support for Xerox Printer??? Don't worry DialXEROX PRINTER CUSTOMER SERVICE+1-877-778-8.9.6.9 and required a solution to your query. Do you have the old version printer so don't worry. We will have exchange offers for the printer, Hurry up makes call on our Tollfree +1-877-778-8.9.6.9 and get the best response. For more information visit us: http://printertechnicalhelp.com/xerox-printer-technicalhelp.html
Posted on Nov 25, 2016
SOURCE: how to print a configuration
how to print a configuration page from a Tally
Posted on Dec 19, 2008
  • 114 Answers
SOURCE: My Tally T6218 gives the
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Posted on Jan 30, 2009
  • 114 Answers
SOURCE: sotutions
there is no shuttle in 6306 printer . so the problem will never come.
  • 114 Answers
SOURCE: Tally T6215 does not power up
There is two reason behind the problem (1)Power Supply . (2) logic Board. At first check the power supply if the power supply is ok then change the logic board.
Posted on Feb 01, 2009
  • 114 Answers
SOURCE: Genicom Tally T6215 not printing on edges.
Adjust the platen screw manualy.
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
My tally printer T6215 HAS A CPU LOST PROBLEM
The problem comming from the power supply of your printer. Check the power supply.
Feb 02, 2009 | Tally T6215 Matrix Printer
My Tally T6218 gives the following error message shuttle fault
Nov 30, 2008 | Tally T6218 Matrix Printer
Jun 12, 2008 | Tally Line Matrix T6215 Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally Line Matrix T6215 Printer Logo
121 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Computer Links
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
