Question about Samsung RS2534 Side by Side Refrigerator
Have recently moved house and left the water connection (to the mains) to the side by side fridge at the old place,,,,,,,,,,,,,,Not sure which connections I now need both from the main water and the white plastic feed pipe to the fridge could you identify the correct parts to me please
    Problem Solver:
  • 9 Answers
Icemaker installation kit
Posted on Jul 21, 2010
Top door will not close by itself on fridge
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Nov 28, 2014 | Electrolux Refrigerators
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
Connect water
The water connection for your fridge can be found on the Left bottom rear corner. It will be a 1/4" compression connection, which most likely you already had connected to old fridge. Hope this helps
Jul 24, 2010 | Electrolux EI26SS55GS Stainless Steel ...
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Water filter housing keeps breaking
Perhaps your refrigerator is too cold. Place a thermometer inside the fridge near the filter housing and leave it overnight. It should read more than 34°F the next morning. Any lower and the water inside the filter will start to freeze, breaking the housing.
If it's too cold, try raising the temp a couple of degrees. Otherwise, move items away from the vents in back to prevent cold spots.
Good luck !
Marco
Feb 06, 2009 | Frigidaire FRS23R4A Side by Side...
Water and Ice Not working on Fridge!
check you water valve make sure you have power to it when the water paddle is pressed... you may have a bad water valve
Jun 26, 2008 | Frigidaire FRS26R4A Side by Side...
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
I moved, and now the water no longer comes out the door
The electrical connector at the top of the hinge cover is not connected properly.  Pull the left hinge cover and make sure that the electrical connections are secure.
Jun 19, 2007 | LG LRFD21855 Stainless Steel French Door...
Samsung RS2534 Side by Side Refrigerator Logo
85 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
