I have a roland boss br-8, it worked well for 5 years, then all of a sudden it started turning off a second after i turned it on. sometimes the BOSS screen comes up for a moment, sometimes the screen just lights up but will remain blank and wont turn off. i've tried different outlets and a different power adapter, no change
  • 1 more comment
  • Anonymous May 24, 2008
    YES WHARES THE ON BOARD BATTERY
  • Anonymous Jul 03, 2008
    Hi, my boss br8 comes on when power button is turn on,but with a blank screen and will not turn off .
  • larrymcclell Dec 03, 2009
    Where is the battery for the B R 8
    Sergeant:
    Champion:
  • 319 Answers
This unit uses a 9 volt battery and/or 9v adaptor. If it malfunctions, it might have processor lock up. A weak on-board battery will prevent reset even when you unplug adaptor. Remove battery and let unit sit unpowered for 24 hours. Install new battery and re-try.
Posted on Apr 24, 2008
There is a problem with the internal power set up.
Posted on Apr 23, 2008
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Boss br 900cd! pls help
If it does not power up, it is likely going to be a faulty or severly dirty switch contact or a failed capacitor in the power supply. A shot of contact cleaner is usually enough to rectify the first issue, The second issue you need to locate the part at fault and replace it.
Apr 26, 2012 | Roland Boss BR 900cd Digital Recorder BR...
Boss br-600 unsupported card
Feb 12, 2012 | Roland BOSS BR 600 8 track portable...
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Dec 06, 2008 | Boss Micro BR Digital Recorder
167 people viewed this question
 Grubhead
Grubhead
