Question about Refrigerators
Samsung model RB193KASB Fridge seems to be not as
Samsung model RB193KASB Fridge seems to be not as cold as it should be
    President:
  • 1,099 Answers
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout...
Posted on Jul 21, 2010
Why is my bottom freezer mod. rb193kasb freezing the food in the lower part of the fridge
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
Jul 06, 2014 | Samsung Refrigerators
Why won't my samsung rb193kasb freezer fan run and the freezer is warm? How do i fix this?
On some Samsung frdge-freezers,fan blades get stuck in ice build-up inside refrigerator compartment due to automatic de-frost not working properly. If you have time, simply switch off and leave fridge door open, and allow defrost to happen naturally. Alternatively, speed up defrost using bowls of hot water, and remove panel at back when enough ice has melted
May 23, 2014 | Samsung Refrigerators
Samsung rb193kasb freezer fan wont run how do i fix it?
usually the fan is turned on by the door switch, and a thermodisk, located on the freon line near the evaporator coil in the freezer...this disk have to be cold enough before the fan come on..
May 23, 2014 | Samsung RS2630SH Side by Side Refrigerator
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Samsung Model SR 21 NME. The freezer is on the top, this freezers fine, but the fridge isnt even cool. We have taken the back off the freeze to do a complete defrost. The fan works fine. But the ttemp dial...
Inside the fridge compartment, at the back, is a panel that can be removed, remove the screws careful with the bulb, its plugged in behind the panel.
the panel has a vent that allows cold air flow from the freezer, this will often freeze completely shut with ice. let it thaw out, then check to see that the vent opens, or closes when you turn the dial, the best thing is to open it as wide as possible, I even used toothpicks to open the valve even more, its just a thin flap, surrounded by Styrofoam.
afterwards if your fridge is too cold, adjust the real thermostat located in the freezer.
Jan 06, 2011 | Samsung Refrigerators
Refrigerators Logo
579 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
