Question about Hawking HWREG1 Repeater
Cannot locate the HW2R1- High Gain Wireless-N Dual Radio..
Hi, Im running Windows 7 Ultimate, 64 bit, and I just bought the product HW2R1. Im using an Wireless (g) receiver from my router that's in the other room. So currently, I plugged the Wireless-N Dual Smart Repeater and in my available networks, it wasn't there.
Also, I downloaded the support utility for this product, but when it locates the Repeater and I click connect it gives me "Repeater Respon Timeout".
Help would be appreciated. Thanks.
tvsandstuff
  • 24 Answers
SOURCE: try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Posted on Nov 20, 2007
SamuRaiii
  • 130 Answers
SOURCE: I cannot connect to my
check cable, you need proper IP configuration
Posted on Dec 15, 2010
  • 6 Answers
SOURCE: HW2R1 repeater is providing an
Is it the repeater or the modem or router.
If you bypass the repeater does it still do it? If not then you might have to "Hard" re-set it. Check your manual on how to do it. It usually involves putting in a paper clip and/or pressing a button but each one is different. You WILL have to re-enter everything again but it's set back to the Default configuration.
If you bypass the repeater and it still happens then it's either the DSL/Cable modem or the Router. Just turn them off or unplug them for 30 seconds or so and then plug the modem in first wait until it's done then the router. Unplugging them or turning them off is considered a "Soft" re-set and just clears the temporary memory and doesn't erase anything else so no reconfiguring.
If after all that maybe it's going bad? Contact the Manufacturer and ask for more answers? They will probably ask for the Version and firmware number to know which exact model you are talking about.
Posted on Jan 08, 2011
Ezrahite
  • 2632 Answers
SOURCE: HI I Have a Hawking
Welcome to Fixya. Have you tried to power cycle the router to refresh the ipaddress and can you please make sure that you're trying to connect to your Network Name, If it requires you with a password make sure you type the right password or Network Key. Network Key is case sensitive. You can obtain the information when you access the router.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 28, 2011
SOURCE: My HW2R1 router keeps disconnecting
You need to reset router to defaults. Also change wireless channel type to 3 or 6 or 11 then check.You can configure channel type with below method .
Press RESET button for 10 seconds it is in the back side of router then all settings defaults. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 15, 2011
Where is ghe router 8 digit pin number for the hw2r1
Ping numbers (Or WPS numbers) are usually on a sticker on the bottom of most wifi / wireless devices. This is ONLY if they support WPS.
If you are sure the device supports WPS and a sticker is not on the bottom you may have to log into the device using a computer that is hard wired (Ethernet cable) to the device.
If you have lost the manual you can download a new one from here
http://hawkingtech.com/products/downloadfile/107.html
Note this link is for the manual to a Hawking HW2R1 ONLY.
Aug 07, 2014 | Hawking HW2R1 Dual Radio Smart Repeater
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Hi, i have an HP printer D5160 and the desplay shows the err 03 31 if f4 dd6 and i can't print anything Thank you Aris T.
Oct 27, 2010 | Office Equipment & Supplies
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Will not print. Have to power off and then power back on for printer to start.
Oct 27, 2010 | HP LaserJet P2015dn Printer
I just bought a new computer that has Windows 7. I try to download my Creatacard Gold3 and am told it is not compatable with a 64 bit driver. Do I throw it out or is there another way to install it?
Two options. Try Googling. Maybe the Creatacard software provider has a 64 bit version of the program available as an upgrade. Many Vista 64 bit programs work OK with Win7.
If this doesn't work and you REALLY need to use THIS program, you can install a 32 bit version of another operating system as a dual-boot. Either XP or Win7 would work. Or run a 32 bit operating system on a virtual machine and run the program on the virtual. That's rather high tech just to run a card maker. So if they don't have a 64 bit version of the program, look for another supplier who does.
64 bit provides faster operations, but it does render a lot of older programs unworkable.
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
Hawking HWREG1 Repeater Logo
127 people viewed this question
Top Hawking Computers & Internet Experts
Marvin
Marvin
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
