Question about GE AJCQ08ACB Air Conditioner
Leaks out the front - GE AJCQ08ACB Air Conditioner
  • GE Master
  • 43,501 Answers
Make sure you are tipped back and that the hole in the back is open...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Smeg dishwasher leaking from front right hand side, cold leak
The door seal may need replacement, the hot water may soften the seal and fix the leak.
Feb 23, 2015 | Smeg Dishwashers
How to find and repair oil leaks in front of motor?
Ok ralph first off clean motor with engine brite found at any auto parts stores
next recommendation add oil base dye to motor oil allow to run for 30 min to circulate dye useing a uv lamp or black light and inspect front cover most cases the front seal is themost likely source of leaks due to contant revolutions on front main seal
in order to repar suspected seal total dissasembly of timing cover will have to be removed in some models the front main bearing journal will have to be removed as well.
upon removal of timing coverbinspect front mail seal race / face for burnishing of the crank seal face. Dirt an debri cut into the crank
you will have to order the front seal repair kit
consists of front seal and stainless steel wear ring wich is glued in with epoxcy
reassemble front timing cover gaskets an sealer may be needed once all the parts are reassembled run for 15 m7n an check for leaks
its also possible that the oil pan gasket could be leaking as well
install dye to find leak is the best course of action first
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
Jun 22, 2014 | 2003 Chevrolet Impala
Oil leak - I see oil in the garage every morning -
check what colour the oil is firstly--- red --transmission oil==black --engine oil===dark brown --gear/diff oil. Next check the position of the oil between the front wheels - red -transmission cooler lines leak /power steering leak
black between the front wheels-- front crank seal. If you have a front drive car then you will have to be careful but the colour will tell you what is leaking and where.
Dec 30, 2013 | Hyundai Tucson Cars & Trucks
Have front pump seal leak fixed but am sill leaking from there no groves on tork where can it be leaking from
there could be wear in the bushing inside the front pump or the leak could be the seal on the front pump to the case
Jun 23, 2012 | Cars & Trucks
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Leaky transmission fluid. possible reasons?
TRANSMISSION LEAKS COME FROM TRANSMISSION OIL PAN GASKET LEAKING.OIL COOLERS LINES LEAKING.LEAKING AT TORQUE CONVERTER FRONT SEAL.TRANSMISSION SPEED SENSOR SEAL LEAKING.FRONT AXLE SEALS LEAKING AND LEAKING AT TRANSMISSION COOLING LINES TO RADIATOR.CHECK ALL YOU WILL FIND LEAK.IF YOU HAVE FAST LEAK OR PRESSURE LEAK.WITH CAR RUNNING IN PARK EMERGENCY BRAKE APPLIED LOOK UNDER CAR IF YOU SEE FLUID LEAKING OUT IN LARGE QUANITIES.COOLER LINES LEAKING OR TORQUE CONVERTER FRONT SEAL LEAKING.IF YOU HAVE SLOW LEAK THE LEAKS HAS TO BE AXLES SEALS OR PAN GASKET LEAKING OR VSS SENSOR SEAL LEAKING.
Aug 03, 2010 | 1998 Pontiac Bonneville
Transmission leaking nearfront changed front seal still leaking transmission fluid
Most transissions front leak is the front seal but it can also be the pump gasket over flow expelling fluid.To save money you should first change the filter. Them if it still leaks pull the trany and pull the front pump and change the gaskets and seals. If this does not fix it then you should seek professional help.
Jun 20, 2009 | 1999 Chevrolet Silverado 1500
GE AJCQ08ACB Air Conditioner Logo
69 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
