Question about ASUS V8420/TD Graphic Card
Defect ASUS V8420 ?
As soon as I plug in my monitor in the ASUS V8420/128M (TVRD)
the monitor stops working. When monitor is unplugged again, the monitor works again.
best regards
  • 1 more comment
  • lereng Apr 22, 2008
    The system used to work ok.
    But suddenly there was no picture on the monitor.
    I thought that the problem was the monitor, like broken fly back trafo or something else wrong with the high voltage circuit.
    But as soon as I unplugged the monitor to replace with another one, the monitor switched on and of course gave me a no sync or no signal message, but as soon as I plug back in the monitor it switches of again.
    I presume there is something wrong with the video card.
  • Anonymous Oct 13, 2008
    video card has gone out my fan quite working and cause it to shut off the monitor
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    r u using any graphic card
Yes you are correct. It is an old CRT type monitor. (LG studioworks 995E). Worked perfect (for my purpose).
When I reboot I do not see anything. Monitor stays black.
No power on self test screen, nothing. I really think the card is dead.
By the way, of course I'am using another computer to sent these comments.
Thanks for your help so far anyway.
best regards
Posted on Apr 22, 2008
    Novelist:
  • 150 Answers
I don't understand, please explain more:
0) What kind of a monitor is it ?
1) If the monitor is NOT plugged into a working video card,
it should blank out or display some sort of a
"NO SYNC" or "NO SIGNAL" or "UNPLUGGED" warning.
The power light may also flash or show a different color.
2) If the monitor is plugged into a working video card,
it should wake up from the inactive power-saving mode
and display the desktop.
3) If the video card is malfunctioning, or if the windows
video settings are set outside of the monitor's sync limits,
the monitor may turn off or display a warning message,
such as:
No sync, Out of range ... etc.
4) The repair situation (3), reboot windows into
safe mode:
a) Press Hardware Reset
b) After the power-on self-test (POST) and memory check
press and hold the F8 Key
c) Select Safe mode
d) Login to windows at low resolution
e) Right-click on the desktop, chose:
Properties -> Settings -> Set the correct resolution, apply
Click advanced -> monitor -> set the correct refresh rate.
Reboot normally
Hope this helps
Martin
PS, some monitors have dual inputs: VGA or DVI
make sure the correct input is selected, depending
on your cable (VGA is a 15 pin "D" connector,
DVI is a larger connector with many more FLAT pins)
Also some video cards have multiple outputs, which are
activated only if a correct monitor is attached BEFORE
reset.
  • Martin J Stadler
    Martin J Stadler Apr 22, 2008
    Am I correct in assuming this is an older CRT type monitor, since you mention the fly-back, LCD flat screens do not have one, they
    work on low voltages an entirely different principles.
    Anyway I do not think that the video card is dead, since it is
    generating a sync which is being detected when the monitor goes out.
    1) It is more likely that this is a VIDEO SETTING, such as:
    a) resolution is set too high
    b) refresh rate is set too high or invalid for the monitor.
    c) the sync type and/or polarity is set wrong
    d) the video card and/or the computer is in standby mode
    Does this happen when you are in windows, or does it happen
    during boot ?
    When you reboot the computer: Do you see the VIDEO BIOS
    information screen? Do you see the Power on Self Test screen?
    Do you see and text on the screen when you power it up?
    or does it die when windows switches to hi res mode.
    Martin
Is asus a9250/td/128m/a compatible with directx 9?
that sounds like the ati radeon 9250- 128mb, and, if so, it is dx9 compatible.
Dec 23, 2014 | ASUS Computers & Internet
PS3 asus mx279h hdmi black screen
When you turn on the PS3 hold the power button and it should do a couple of beeps this means it has reset the video output and should work :)
Jan 11, 2014 | ASUS Computers & Internet
Hi! Ive bought an Asus LS246h today and it won't start. Ive checked all cables and Ive got power on the power plug. None of the lights at the monitor are working! Is my monitor defect?
Hello there,
It looks like you have a faulty monitor. Make sure the power is plugged in at the computer and a working all socket. Make sure that the Box on the power cord is connected properly. Make sure that the connections to the computer and secure and that the computer is turned on. If none of these things fix the monitor, I recommend returning it and getting it replace.
I hope this has helped! Thumbs up are much appreciated.
May 07, 2011 | ASUS LS246H Monitor
Asus monitor vw224u stopped working, found was partially unplugged, plugged back in, rebooted, shut down, restarted but monitor says no VGA signal
Try pressing the S/A button to change input sources.(the button on the far left on the front of the monitor) Chances are the cable got unplugged, then the monitor when into analog mode and its now stuck there, because many monitors default to analog.
Feb 27, 2011 | ASUS VW224U 22 inch Monitor
Is there a driver for V8420 Delux Graphic Card for windows 7 ?
No. Drivers for this card were released up to XP.
This card is built on an NVidia GeForce 8 series chip. You can try the latest driver pack for GEForce 8, I don't know if it will work.
Here link.
Regards.
Nov 09, 2010 | ASUS V8420/Deluxe (128 MB) Graphic Card
My hp w1907 monitor has suddenly stopped working!!as soon as i turn on the tower it just displays"monitor is going to sleep"PLEASE HELP!!!
I love this one. I've actually done this many times before and have been successful.
1. Turn the computer off and unplug the power cord from the back of the tower.
2. Press and hold the power button for about 3 seconds while the computer is unplugged (this drains the remaining power from the capacitors on the motherboard).
3. Plug the computer back in and turn it on.
If that does not work, follow steps 1 and 2 again, but this time:
3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
4. Plug everything back in and turn the computer on.
Mar 13, 2010 | HP w1907 LCD Monitor
Ok So i have a Biostar TA785GE 128M with a Phenom II X4 965 Processor. So ive plugged everything in and the problem is that when i plug the monitor cable thing into my video card, the monitor doesnt have a...
if your mobo has built in video output, connect your monitor to that 1st. if your able to get to the bios, change the primary vga port to PCI-e,save and exit. then reconnect your monitor to your video card..
Hope it helps!
Feb 14, 2010 | Biostar TA785GE 128M AM2+/AM3 AMD 785G...
ASUS V8420/TD Graphic Card Logo
239 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
