Question about Quad Disc Brake Rotor 160mm Bicycle Bike
No spark quadzilla pro shark
Quad bike quadzilla ihad a faint spark so i changed the spark plug still the same so ichanged the cdi unit and the coil now i have no spark ive tried the cut off switch and it is still the same the quad bike is a pro shark 100cc water cool i need help
2 Suggested Answers
SOURCE: hi there ,i purchaced a 110cc chineese import quad
Try checking the ignition coil, or the CDI.
Posted on Oct 13, 2009
What wires to test coil and stator. no spark.
how to fix no spark and wire pit bike - YouTube
? 4:59
https://www.youtube.com/watch?v=YX8WRLN5gZ4
Nov 25, 2013 - Uploaded by coryncheryl1
how to fix no spark and wire pit bike. coryncheryl1 ... Chinese Quad 110cc wiring hack making SPARKS !!! No ...
GY6 150cc Ignition Troubleshooting Guide: No Spark? - BD ...
www.buggydepot.com/.../gy6-150cc-ignition-troubleshooting-guide-no-...
May 27, 2014 - Stator (6th winding and trigger pickup module); CDI unit; Ignition coil; Spark ... to check for voltage at the two primary wires of the ignition coil.
Trouble Shooter Guide for NO-SPARK Chinese Engines
www.kazumaracing.com > ... > Chinese ATV Service Manuals
Number 2 is the ignition coil and that is easily found because the large wire and cap ... The final third component is the stator magnetor or magnetic pickup coil.
My vehicle has no spark. How do I test the stator ...
support.familygokarts.com/.../21258173-My-vehicle-has-no-spark-How-...
Apr 11, 2012 - 90% of no spark is caused by the CDI Charge Coil in the Stator. ... Thestator is located on engine side housing, where a 5 wire unit is coming ...
Bad Stator Fix - Instructables
Jan 06, 2016 | Motorcycles
Quadzilla rl300
1) CHECK THE RESISTANCE OF THE PULSER COIL. APRROXIMATE VALUE 200 OHMS
2) CHECK THE IGNITION COIL
Aug 24, 2014 | Motorcycles
50cc apache quad spark problems
Could be the CDI. Check the stator and pickup coil specs with a multimeter first.
Nov 17, 2013 | ATVs
Quadzilla bike is startin but everytime u try to give it gas it cuts off and it is not revving
Air,fuel and spark
Pull the air filter and do a quick inspection.
Add a small amount of yellow HEET to rule out moisture in fuel
Pull the boot out and use a screw driver to check CDI unit for spark.
Sep 25, 2013 | Quadzilla Batwing Fairing - Honda VTX 1800...
Mazuma quad no spark
I've heard that the CDI box tends to go and usually costs around 5 bucks although I don't know how to test them yet
Jun 28, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
How to test CDI unit for KTM65 2009 to diagnose if faulty or not.
If you are able to use a digital volt meter and work your backwards from spark plug wire to coil to cdi to stator you can figure out where voltage stops.thats a fairly newer bike unless you really submerged that bike under water i dont think its the cdi box.it could be coil wire it could be coil.you want to check or change the cheaper parts before you go right to cdi because there not cheap.I have a yamaha banshee 350 and she was breaking up real bad.I thought because it was only happining on top end that the cdi was breaking down or stator was going bad.Found out with meter it was the coil wires and spark plug boots.These items have to have a certain amount of resistance or the do not conduct correctly.And spark plug wires and boots are not that exspensive.So thats why I say start from sparkplug boot and work your way back.Try that and Good Luck.
May 09, 2011 | 2009 KTM 65 SX
Can you tell me where the spark plugs are on my quadzilla 250e lost booklet and am new to quads many thanks
Observe the bikes engine where the only wiring connection is attached. Spark plugs are enclosed within a plastic coating. Decipher from the bikes picture at the bock directly below gasoline tank is an engine block. The top part has an outlet connection for wiring cables. Aslo ascertaining the spark plugs by tracing the exhaust pipes through until arriving at the engine as the cyclinder block. However, the sparks are found at the top of the engine.
Mar 13, 2011 | 1971 Suzuki T 350
Hi i have a dinli 100cc quad bike .the quad will nt start and there is no ignition i have checked the spark plug so can you help me if you can i will be very happy
I assume that is a 100cc, 2 stroke ATV? If the starter motor is spinning, and you just don't have any spark. First, replace the spark plug. If that doesn't fix it, then you may have one of the following problems: Bad CDI, Kill Switch or Rip Cord Shut off switch, Frayed wire shorting out, cracked/damaged spark plug cap, bad coil or coil wire, bad stator. My bet is on the kill switch and/or Lanyard/Rip Cord shut off switch or the CDI. You can bypass your shutoff switches to see if they are the problem by either disconnecting the wires or connecting them together(depending on the type of system you have). CDI's routinely fail on small engines and generally cost about $20-$70, depending on the style. www.solanocycle.com
Jan 02, 2011 | Derbi Cross city Motorcycles
I have no spark on a ducar 110cc quad
test all connections,for strength by bending them
Sep 22, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Quad Disc Brake Rotor 160mm Bicycle Bike Logo
418 people viewed this question
Top Quad Cycling Experts
Marvin
Marvin
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
