Sharp Copier al 1611 - what does ch mean when it comes up on the screen for the number count?
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
  • 81 Answers
SOURCE: Sharp Copier 2025 error steady CH
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Posted on Jul 24, 2008
  • 87 Answers
SOURCE: green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Posted on Dec 31, 2008
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
  • 43 Answers
SOURCE: What does E7 Error code
?7 03 Problem related to the brightness of the laser emission 04 Error in determining the level of white in the performance of hatching 05 Error in determining the level of black during hatching 12 Error output level in the performance of hatching 14 Failure ASIC (MCU PWB) 15 Trouble copying lamps
Posted on Sep 20, 2010
I am getting a ch message on my sharp al-1631 copier and can not find the manual. Do you know what this means?
CH stands for close hatch check that the front and side doors are closed. (open both then close again)
Jun 21, 2011 | Sharp AL 1631 Copier
We have a Sharp AL-1642CS Copier machine. That currently isn't working. What does a CH code mean?
CH code = Toner Cartridge is missing or not installed properly. In rare cases it is a defective toner cartridge. Also double check the right side and front doors proper closure.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1642CS Copier
CH CODE COMES UP ON DISPLAY
Most of the time on Sharp products, CH means your ink cartridge is empty.
Jul 18, 2010 | Sharp AL 800 Copier
What does message ch mean?
If your copier front or right cove is not attached properly then CH on standby, or CH is blinking/flashing may be your copier TD unite is not adjust or close.
Dec 28, 2009 | Sharp AL 1631 Copier
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
What does "CH" mean?
On the Sharp copiers when the "ch" is blinking means that the toner cartridge is not in or it may be the wrong cartridge. Some sharp cartridges look alike and will fit into the machine but are the wrong one.
Hope that helps...
Lbcoaster
Feb 18, 2009 | Sharp AL-1642CS Copier
Solution for "CH" code given by the copier Sharp SF2022
Hello sir; CH code means somewhere the door open , it seems like right hand side door did not close right.
Feb 13, 2009 | Sharp AL 1631 Copier
Green blinking light CH
Dec 24, 2008 | Sharp AL 1631 Copier
Digital Copier
I believe a ch code on sharp is an indcation one of the covers is open.
Mar 23, 2007 | Sharp AL 800 Copier
jasbo
jasbo
