Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How can I use my HP Officejet 6500 with magic jack usb system? Interested in switch to magic jack, but I want to be able to use my fax as well.
I have the Magic Jack that works fine. Every since3 I installed the Majic Jacj my Hewlette Packard printer HP PSC 2350 ALL in One won't connect and it seems as if it is a USB problem. Any solutions?
Posted on Jan 17, 2011
  • Canon36 Jan 17, 2011
    This was supposed to be a question for someone.
How do i fax with magic jack
Initialize the the magic jack first.Connect the phone cable to the fax machine/printer and the magic jack. listen for a dial tone and send fax as usual.
Feb 09, 2016 | HP Officejet 4620 All in One
HP OFFICEJET 6500 SAYS NO COMPUTER CONNECTED WHEN RECEIVING A FAX, BUT PRINTS FROM THE SAME COMPUTER
to receive fax, you must connect the fax line to the printer. All-in-one printer can received fax without computer.
Sep 26, 2011 | HP Officejet 6500 Wireless All-in-One...
How get faxed confirmation HP officejet 6500
You can enable fax confirmation before sending a fax by selecting Send & Receive
Press SETUP on the control panel
Press PRINT REPORT, then FAX CONFIRMATION
Press right arrow to select SEND & RECEIVE
Press OK
Additional instructions from HP Support User Guide
Click on link and select FAX
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Feb 19, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a HP Officejet 6500 wireless all in one printer. When I try to fax it says sending but then I get a "no answer" result. What should I check?
Tell it to send a FAX to your cell-phone or iPhone number.
When your phone rings, answer it.
Then, check the status on the HP OfficeJet.
It should switch from "calling" to "answered" to "synchronizing/negotiating".
Sep 02, 2010 | HP Officejet 6500 Wireless All-in-One...
HP6210 faxing with MagicJack---Any suggestions?
Try using the magic jack on a seperate computer, you are using two lines at once with the fax and the magic on the same machine and it sounds like it's causing a usb problem
May 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Need operating instructions for HP Officejet 6500 E709. How do you send a fax?
Hi:
You can go to www.hp.com Click on the support and drivers tab, type in the model of your HP officejet 6500, and you can download the entire manual for free.
Nov 10, 2009 | HP Officejet 6500 Wireless All-in-One...
Faxes do not send or receive using Magic jack
if its ooficejet,then u shud use 2 prong cable,wire that is coming out from wall jack shoud be directly connected to the line port of the printer and if u are using a tam that shoud be connected to the ext port of the printer,and if this doesn't work,then 1 thing you can do,remove the tam from the phone,and in case if you cannot remove,turn off the tam and then try to send,you wud be able to,and use only two prong cable,and i beleive you are not using voip connection....
Aug 25, 2009 | HP Officejet 6500 Wireless All-in-One...
Slow down officejet v40 fax transmittion
Magic jack is lying to you. It is a DIGITAL phone service, fax machines are ANALOG
Feb 19, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
420 people viewed this question
Ben Johnson
