Question about Apple PowerBook G4 Mac Notebook
G4 powerbook wont start it shows folder with flashing question mark then apple symbol
  • 863 Answers
Try taking out the RAM chips and re-inserting firmly. Nothing? Try re-installing the operating system. Nothing? Try replacing the hard drive and then re-installing the operating system. Nothing? Try replacing the RAM with new higher memory RAM. Nothing? Your fu.kd and need to take the thing in for more thorough inspection by the Apple dorks.
Posted on Oct 07, 2010
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
I changed the hard drive in my powerbook g4 17in how do i in stall snow leopard on it it has a folder with a flashing question mark and finder
It seems that snow leopard is only installable on macs with intel processors, and yours is PowerPC.
see more here: http://www.apple.com/macosx/specs.html
Aug 23, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My Powerbook G4 turns on light, fan, chime but no video.
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
May 08, 2010 | Apple PowerBook G4 Mac Notebook
My mac powerbook is displaying a folder which flashes between a question mark and a icon in the middle of the folder it stays on the grey start up screen and doesnt start up any suggestion???
Your PB can't find the system. Most likely you hard drive is no longer working. To check that this is the case, start up from the discs that came with your computer.You will need to replace the hard drive then re-install the operating system off those discs. I hope you had a backup of your data!
Feb 21, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
Mac Powerbook shows file wih flashing question mark, won't boot.
The flashing question mark means that the computer can't find an OS.
If the computer previously was working, start up from the OSX disc and run 'Disc Utility' from the 'Utilities' menu in the top toolbar.
Run 'First Aid' to check and repair any errors.
If the computer still can't find an OS then you will need to re-install OSX.
Apr 15, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 wont start up, shows a file folder with a ? mark....
The hard drive is probably on it's way out. You can get and run Disk Warrior and you could repair permissions and such but the hard drive is probably on it's way to the grave.
A couple things though. It isn't enough to just put the disk in, you need to hold down "c" while the computer starts for it to try to run off your disk. You can then try to repair permissions and fix the disk from the installation program that starts. When the Install OS X screen comes up (looks like a desktop but with the big dialog box in the middle) click on Utilities at the top and then on Disk Utility. HERE IS APPLE'S SITE for you to read about how to try to repair your disk. I've found that this sometimes works and may help it work enough for you to get your files off, but may not.
Another method would be to get another Mac, and hook the two together with a firewire to transfer your files, then reinstall OS X in your ailing computer. Go HERE to read about this technique.
Feb 19, 2009 | Apple PowerBook G4 Mac Notebook
Apple mac g4 laptop wont come on
Kernel panics are not what you have, you have a flashing question mark, it indicates there is a problem with either the hard drive or the operating system on the hard drive.
Kernel panics are different, the unit tries to start and then the unit crashes with a "kernel panic"
Apple PowerBook G4 Mac Notebook Logo
262 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
