This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
Go your message setting. There is option where you'll save your message and choose save to memory card. Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message. If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most. If the problem persist, format your phone back to factory setting.
This is because when you send the message it stores up in outbox and then only it wil be sent,As your phone memory is full no space is there for storing in the outbox. So please delete the inbox and draft and savedmessages so that you will not get this message again.
This is because when you send a text message it gets stored in the outbox and it wil be sent.As there is no memory in the phone the message sent cannot be stored up in outbox which says memory full.
Please delete the images ,music files from the phone memory so that you can sent the text messages with photos.
sir your phone memory is full.empty your inbox and outbox and format your handset by using the following code *#7370#
it will require your phone lock code which is 12345 in default.
good luck
Hold down the HOME button for 3 second, it will show you all opened apps running on backround.Also try remove battery for 5-10 minutes. Check your Message folders (drafts,sent etc). Do an firmware update as well.
