Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter thermostat 44860
How do I set the heat without getting the fan along? all I get is cold air coming from the registers the screen is red but I can not find a way to stop the fan
thanks
  • 1 more comment
  • Anonymous Jun 08, 2008
    Lost manual and can not program temperature. Model 44860. We used to have no problems. G Martin
  • Anonymous Oct 19, 2008
    how do I set the heat without getting the fan along? all I get is cold air coming from the registers the screen is red but I can not find a way to stop the fan
    I am trying to go from ac to heat and only the fan will run with my heat strips and not the unit itself
  • Anonymous Feb 03, 2009
    Hello friend
    did you know how to adjust the fan on the pump heat for cooling or heating? the reason I ask is because I not quite sure how to adjust this thermostat
    thank you
How do I set the air conditioning? I'm lost on this thing and I can't find my manual. Apparently the one I saved is in Spanish. Please help, it's getting warm here in Ohio.....and I have horrible asthma.
Posted on Apr 25, 2008
  • 552 Answers
Here is a link to the Hunter website.
If you need further assistance, please let me know.
Posted on Apr 23, 2008
Hit just to the left of the temperature and you will see a fan symbol pop up. Make sure the fan is set to the correct setting. Refresh means the fan will come on every 15 minutes or so no matter what the tempurature. Auto is usually the normal setting I think. Program mode - depends if you have programs. On mode means the fan is always on.
Posted on Oct 22, 2008
  • bitter8girl Oct 22, 2008
    TGRIFFIN:
    To find the air-conditioning, again, click just left of the temperature. Number should disappear and you should be able to chose Air, Heat, Auto, etc.
I cannot get my thermostat off of the temporary hold mode....
My manual seems to have every language except English.
Posted on Jul 16, 2011
Air handler fan runs continuosly. Will not shut off.
There should be fan options "automatic" which will turn on with heat or cool. , continuous, and perhaps "circulate" which is a randomized turn and off. Double-check your Thermostat programming manual. If no manual,
Try this: http://www.manualslib.com/
Mar 04, 2015 | Hunter Universal Touchscreen Thermostat...
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Hunter 44860 Thermostat - continually resets clock to 1am
My Hunter 44860 is doing this also. It started on Nov. 1, 2009. It also displays the day of the week as "SUNDAYAY" when it hangs. I believe this is a firmware problem with older stock. Unfortunately I bought it from Lowes this fall and lost the receipt. I am going to try to return it to Hunter Fan Co for an exchange.
Nov 09, 2009 | Heating & Cooling
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Hunter 44860 says heat is running
Does the indoor blower come on when you switch the unit to "Fan/ Run"? If the indoor fan comes on, this verifies that you have both low voltage and high voltage to the unit. If not, you may have one or both voltages giving you a problem. Try this and let's see if we can get it going. This is step one in checking it out.
Good luck and hope this helps
Mar 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Installation
IMPORTANT THEASE ARE TRADE STANDERD
red to r
green to g
white to w
blue to y assuming
  • R: It is the main transformer low voltage wire. It comes off of the transformer and feeds to the thermostat.
  • Y: It is the compressor wire and is connected to the other side of the compressor.
  • G: It is for fan. It is connected to one side of the fan relay and there is a common wire on the other side.
  • W: It is for strip heat. The strip heat has a relay and common side. The wire is connected to the other side.
  • Jan 12, 2009 | Hunter Fan Company 5/1/1 Programmable...
    44860 thermostat won't activate in heat mode
    I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
    Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
    Hunter Fan Company 5/1/1 Programmable Thermostat Logo
    2,222 people viewed this question
    Top Hunter Dryers Experts
    Paul Bade
    Thomas Perkins
    Thomas Perkins
    Are you a Hunter Dryer Expert? Answer questions, earn points and help others
