Question about Samsung YP-T10 Digital Media Player
Hi my yp-t10 2GB can't be switched on
My t-10 is able to connect to the computer via usb and the screen and the touch pad is working.when i on the device,the screed just flash a bit bright for less than 1 second and nothing happened. i tried reseting but it didt work
  • 2 more comments
  • com noob Apr 22, 2008
    no battery..
  • mangawy Apr 29, 2008
    the same thing
  • mach6ix May 09, 2008
    Updated the firmware. Very confident the update process went as it should. Unit will only stay on, yet unusable, when connected to the PC as it's in USB connect mode.
    Once disconnected and turned on, no matter how long i have it connected previous, there is no power and the unit shuts down. Any idea's?
  • Anonymous Oct 06, 2008
    same here
  • 8,596 Answers
There is one last ditch method, but this is most likely a hardware issue that cannot be resolved without replacement:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
Konica minolta 350 touch screen stopped working
Similar problem with a Canon MG6320 has been solved .There is an updated firmware for this printer that fixest his issue. Download and run it on your computer that is connected via a USB cord directly to the printer.
Jun 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
NEW SAMSUNG YP-K3 DOESN'T CHARGE
The problem is with the battery or the USB cable.
Check the cable first if there is any damage replace it,if there is no damage then the problem is with the battery which is not charging get it replaced and ur problem will be solved..
If you have any other problems please feel free to ask..
Goodluck..
Feb 10, 2008 | Samsung YP-K3 MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
USB connection problem
my YP-U3 player will not connect via my USB port. When plugged in to a port that connects my digital camera normally it first says on screen "USB Connecting" then changes after 2 to 3 seconds to "disconnected - Charging". it has fully charged and no change. I have checked the hold switch is disengaged. the media studio software is installed ok and the portable devices functions are greyed out. I cannot find the device on my pc. I am running Windows XP SP2. I will be returning it to the store where it was purchased very soon if i cannot find a solution. I notice there are a lot of people who have posted similar problems that have not recieved solutions.ya i have th same problem im using window xp 2
Aug 30, 2008 | Samsung YP-U3 MP3 Player
Samsung YP T9 4GB USB Fault
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall, reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfixIf that doesn't fix it try the USB cable
Jan 24, 2008 | Samsung Yepp YP-T9 Digital Media Player
Touchpad not working
If you have a wireless mouse or a USB mouse plug in and get online to find a downloadable driver for your touch-pad. A lot of file adding and shifting with a touch-pad can get the system fragmented (Defragging may help) and driver files, .dll's, and others your touch-pad needs and uses can get buried in the clutter (file fragments) all over the floor so-to-speak. If defragmentation of your hard drive doesn't work just download new drivers. Here is a safe Download link to look in. There is just about everything here, free and safe too...
Mouse Drivers software for Windows Free Software Apps and Games
May 24, 2017 | Samsung Yepp YP-Z5QB MP3 Player
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Oct 23, 2007 | Samsung YP-Z5 MP3 Player
I can't connect my samsung yp-z5 to the computer!!!
Try installing the Samsung Media package supplied with the player. Then restart your PC - all programs should then recognise the YP-Z5
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-T10 Digital Media Player Logo
231 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
