What is the rating of the rectifier in the Goodmans GHD1621F2 pvr?
GOODMANS GHD1621F2 FROZEN WHAT CAN I DO
Posted on Aug 14, 2010
Hi team I have 230volts at input pl32 but on switch on . Fault may have been a power surge .Thank you for any help Ray Styles ALSO badged Goodmans and Kenwood. pvr 160gB twin tuner hdd recorder
have you checked i f the rectifiers -diodes are stopping the minus part of the ac current,making it a dc voltage,ther either 4 single diodes or 1 round one which has 4 legs you want to measure the terminal marked with a plus sign i think,this should be a smooth dc voltage of half the input ac voltage ,in this case around 115 vdc.,it may been a power surge have you the mains suppressent capacitor,s this usually there to take the surge of 240 mains supply ,supplied by your energy company.during busy usage,there is usually a power surge ie,during tv ads,ets. is there any input /output current/voltage,to the dc transformer or out of it,have you followed the voltage/current throug the power supply circuit.
May 11, 2010 | Televison & Video
I Bought a Goodmans 250Gb Digital Freeview box in
As it's only May, I would take it straight back to the shop and demand a new one/alternative.
If it is bust, and it's in warranty, I certainly wouldn't try and fix it as you may invalidate the warranty by opening the case to check wires etc.
May 14, 2009 | Audio Players & Recorders
Remote Control Code for Goodmans GHD8150F2 PVR
not all universal remote control work with everything, even if the product is listed.
You MUST try every code in the book and see if another company code works.
Nov 29, 2008 | Televison & Video
Lipsinc prob. with Goodmans GHD1621F2 DTR
take it back to currys see if it works on one of there systems if so then it must be down to your system ?
Jan 26, 2008 | Televison & Video
Power failer when switching on tv
A fuse blows when there is a fault and it is the first line of protection for the equipment. The fuse used in a typical plug is rated at 4A/220V. This means that a indeed fault does exist inside the equipment that is forcing it to draw a current greater than the rated. Almost certainly, the primary circuit of your Goodmans is at fault. If you are familiar with TV repair then check the bridge rectifier as well as the reservoir capacitor, with the switching semiconductor (BJT or MOSFET or IC) removed. If the fuse blows then the rectifier/capacitor are to blame. If not, then the semiconductor is at fault. If you are a novice, then rather refer servicing to a qualified tech since the risks outweigh the benefits.
Jan 09, 2008 | Televison & Video
Goodmans GPDR40
14th August 2007 I've heard of this problem. The operationg system or part of it is on the hard drive so if something happens to the data the unit gets stuck at the opening window. A suggestion I've read about is to open the unit and try and reconnect the ribbon cable to the drive, it's a push on job apparently. Of course, this will invalidate your guarantee AND may not solve the problem. I've not done it myself so can't give any firsthand advice. Regards
Aug 13, 2007 | Goodmans GPDR40 Digital Media Player
GPDR 40
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work? 6. if you still have problems you can replace the files in pvr data with the following:- http://mustek.com/product_resources/drivers/pvr-upgrades/pvrh140-datafiles/pvr-h140_restore_files.zip good luck Ian
Jul 13, 2007 | Goodmans GPDR40 Digital Media Player
Screen freeze.
Apr 16, 2007 | Goodmans GPDR40 Digital Media Player
Trouble starting up
Dec 15, 2006 | Goodmans GPDR40 Digital Media Player
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
