Question about Panasonic KX-P3196 Matrix Printer
Panasonic KXP-3196 The printer receives the job, starts printing, stops shortly thereafter and all the lights blink accompanied by a high pitch sound that does not stop unless the printer is turned off. The queu says that the job is printing.
    Genius:
  • 1,478 Answers
This looks like a hardware problem on your printer, i will suggest you try replace the cable that connects the printer to your system, if after trying another cable and the problem persist, power off the printer and power on back after few minutes, while the printer is loading, pull out the plug that connects the printer to the AC power outlet, and wait for some minutes before plugging it back, power on and try print to see if it fix the problem.
You can also uninstall the printer driver from your system and reinstall back.
Take care.
Posted on Jul 21, 2010
KXP-3626. How can I print output from a computer using Windows 7?
make sure the printer driver is installed
check that the printer is compatible with win 7 os
Mar 31, 2016 | Panasonic Office Equipment & Supplies
The printer does not accept print jobs and orange warning light is on along with green ready. Both lights sart blinking when a printing job is sent. The printer does not print. How can I fix the probl
Dear
I am not familiar with Ubuntu. So in case of windows SMART PANEL/EASY PRINTER MANAGER can be down loaded from samsung web this will show the errors that the machine has.
Try to print a self (demo page) pressing stop s/w a while. If it works check the life of toner cart.
Thanks.
Sep 19, 2014 | Samsung ML-2571N Laser Printer
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
Pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
Jun 15, 2012 | Panasonic Technics SL-1200MK2 Turntable
I have a Panasonic KX FLB881 MFC Laser Printer purchased in 2/09. Problems started about 60 days ago. Incoming fax calls ring and ring and the unit will not pick-up. Shortly thereafter network...
The printer has gone into cascade failure, it would require circuit boards to be replaced and with the history I would use it strictly as a printer. The cost of repair would put you over the price you originally paid for the unit, and as you pointed out the mechanics of the item is still fine, I agree with the fact use it until it breaks down.
Jan 07, 2011 | Panasonic KX-FLB881 All-In-One Laser...
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
TV making high pitch noise, stop working.
It must be the horizontal output transistor, it maybe short circuited. A short in flyback.
Apr 02, 2009 | Televison & Video
Printer problem
Try replacing your laser unit. They are known to make a high pitch sound when they go bad.
Oct 29, 2008 | HP LaserJet 2200D Printer
On light won't stop blinking and on the display there is an hour glass
there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Light blinking
Sounds like you have a paper jam somewhere. Open up the printer and look for some paper. If the page is still in the machine, sometimes you can gently pull ever so slowly and finish getting the paper out of the machine. Power cycle the machine and if it was a jam, you should be fine.
Jun 07, 2008 | HP DeskJet 3940 InkJet Photo Printer
Panasonic KX-P3196 Matrix Printer Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
