Question about Dell E153FPc 15" TFT LCD Flat Panel Monitor
Self test feature check stuck on screen
Self test feature check stuck floating on screen
    Sergeant:
  • 269 Answers
From my past history dell has/is problems with the E153pc and the E172pb is it under warranty and have you gotten hold of dell about this I have had cases where they have replaced monitors.
sorry it was no great help but dell knows of this problem. dont let them bull**** you.
Posted on Jul 21, 2010
  • Melody Jul 21, 2010
    try this
    Monitor STFC (Self Test Feature Check)
    * Turn off the monitor
    * Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
    * Unplug the monitor video cable from the back of the computer
    * Turn on the monitor
    * The floating red/green/blue/white dialog box should appear on screen against a black background. What appears?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 848 Answers
Self test feature check stuck on screen? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1521HSD1 715L1074 PWPC1521XXD1 Dell ADTV1521HSD1 Power Supply Backlight...
Posted on Feb 11, 2015
Brand new BenQ EW2730V not turning on after 30-40 minutes of use with the XBOX 360/PS3. Is it a feature or something because the power button is blinking orange?
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced
Oct 22, 2013 | BenQ EW2730V 27 WIDE
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
Dell gx270 not communicating with monitor. self test feature check is floating on monitor
This is a self check for the monitor. This self test means that the monitor is not getting a signal from your computer. Have you installed any video cards in this computer?
If its onboard video meaning you never installed a video card then your video card is bad. Try purchasing a video card and installing it in the computer and your problem should be fixed. I hope this helps you. Any other questions feel free to ask thanks.
Jun 23, 2010 | Dell OptiPlex™ GX270 PC Desktop
Screen is showing "Self test feature check" in a box with primary colors floating around the screen.
it mean that
* either the data cable which goes from computer to monitor is loose or bad
* the computer is off or not turning on .
Apr 09, 2010 | Computers & Internet
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flat Panel Monitor: 1907FPt
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E153FPc 15" TFT LCD Flat Panel Monitor Logo
4,063 people viewed this question
Alun Cox
