Question about Breadman TR888 Corner Bakery Bread Maker
We can't find a replacement basket (bottom has jammed) or blade (broken). the machine still working perfectly if we could but put a mix in it. Is it possible to get parts still for Baker's Oven Plus Model No. BB250
    Champion:
  • 268 Answers
Have you looked on ebay or gadget-asia.co.uk, there are chances you will find something
Posted on Apr 22, 2008
Spl-mc180p shredder trouble shooting
Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch.
If that does not solve the problem, Unplug the unit from the electrical, remove the top part from the basket. Pull out as much of the paper from the top and bottom that you can.
Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit. If the motor does not come on, there is a fuse inside the machine that may need to be replaced.
Once you have solved the problem, you should oil the blades after every hour of use, it really makes it easier on the blades.
Also, there is an internal "heat switch" in the machine that will shut it down for about 90 minutes if the motor gets to hot. It is a safety factor in case you get something stuck, like a person wearing a tie, etc. After the machine has cooled down, turn the on/off switch to off and then back to on.
Jul 14, 2014 | OfficeMax 0M96431 Shredder
Can I get a user manual on line since how to unstuck instructions are in the manual. Refers to Royal PX1201 paper shredder.
Jul 12, 2014 | Office Equipment & Supplies
Can a shredder wont goforward be repaired
Jul 12, 2014 | Office Depot Ativa CX10W Shredder
Ativia 391c
Is sounds like you have a paper jam. Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch.
If that does not work, try their Customer Service at:
http://www.ativaproducts.com/contact.html
Jul 11, 2014 | Ativa Office Equipment & Supplies
ACCO 2550
It is possible there is a paper jam.
Unplug the unit from electrical. Remove any scraps of paper from the bottom of the blades.
Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then replug it in the electrical and try running the unit.
If that solves the problem, squirt a small amount of lubricant on the cutting blades for every one hour they are in use.
Jul 10, 2014 | ACCO Office Equipment & Supplies
My blade assembly broke. Can I get a new one for my Maxi 4000
replacement can be found on amazon, take a look here: Amazon com Vitamix blade assembly. I hope this was helpful. Cheers
Jan 16, 2013 | Vitamix Vita Mix Maxi 4000 Commercial...
I can't remove the basket to empty
Its probably jammed with shredded paper to the point where the paper is stopping you from removing the basket. You will just have to try to open it enough and "fish out" some of the paper so that the level goes down and the basket can be removed.
In extreme cases if you let the basket overfill then the "shredded" paper gets caught back up in the cutting blades and you can jam the machine and fry the pcb inside.
Sep 16, 2010 | Royal PX1000MX Shredder
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
Spring came out - where does it go?
That is from your dripp stop. If you can replace it it will be in the bottom of your filter holder. If not Please tkae out the valve on the bottom of this filter holder. You will have no dripp stop but it will work just fine.
Jun 01, 2008 | Krups Aroma Control 197 Coffee Maker
Frigidaire front loader washer
one of the welds on your inner stainless steal tub may have broke causing the drop of your tub.  The tub has a warranty on it but the labor to put it in is around 3hrs give or take any hour.
Oct 23, 2007 | Frigidaire GLTR1670A Front Load Washer
Breadman TR888 Corner Bakery Bread Maker Logo
228 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
