Question about Hayward EC65 Extended Cycle DE In Ground Pool Filter System with Pump
Appears that the silicone sand is being thrown back into the pool from the return jets? I assume something gave out since the filter is old. What part is needed to replace on the EC65 DE Filter?
  • 8,404 Answers
Is this a DE filter or a sand filter: Check all internal parts of your DE filter for holes or breaks. There is a hose inside that is suppose to eliminate air locks ... it may be submerged. Same applies to sand ... find the broken lateral or air lock preventing hose.
If you have a DE filter and sand is coming into the pool ... there is definitely a hole returning sand that bathers introduced into the pool ...
You are using DE in your DE filter, right??? not sand ... right???
Posted on Aug 04, 2010
Sand filter seems to be working fine but a couple of days after I backwash I notice sand in the bottom of pool. I assume it is coming from filter. What can I do to fix this.
Vacuum it up. This fine sand will return to the sand filter and become trapped. Normal operation for a sand filter. Consider an automatic pool sweep, like Polaris. That will take this "problem" off your mind.
May 20, 2017 | Washing Machines
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Gary
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
This spring we changed the sand in our filter. Sand was purchase from the same location we purchased our pool. When i vaccuum the pool the dirty water is sent out the return back into the pool and the...
I don't like sand filters very much but that still should not be happening. If you have a multiport valve on your filter, take it apart and see if the spider gasket is in good condition and if it's secure. Sometimes if a spider gasket swells it can push its way out of the grooves where it is fastened. Also, if you have ever turned the multiport selector know without fully depressing it, if could have pulled a part of the gasket out and it's now letting water return to the pool without being filtered at all.
New sand should not be causing this problem, check your multiport and see if that is the problem.
Hope this helps
Jul 30, 2011 | Hayward SAND FILTER, PRO SERIES
I have an Hayward Pro Series S244T filter and I have had problems with sand blowing back into pool - the filter is only 2 years old
When sand returns to the pool, there is a hole in either the media or the sieve that is supposed to keep the sand in the filter.
All of the sand must come out of the filter, the sieve at the bottom (outlet of the filter) must be removed and any broken segments must be replaced.
The sand is then returned.
Gary
Apr 27, 2011 | Hayward SAND FILTER, PRO SERIES
We had a lot of rain and mud got in the pool. i vacuumed the pool twice and the third time i vacuumed it, i put the filter on "waste" instead of keeping it on "filter". it cleaned up very well that way...
You may have to change the sand from to much mud. this requires removing the valve from the top and syphoning the sand with a "sand changer" then removing the latterals from the bottom.( they unscrew from the hub inside the filter and cleaning them. Return the correct the amount of sand covering the tube shaft that connects the valve to the hub sot he sand doesnot clog the flow again. Return valve to the top and it should flow freely again.
The Pool Tech
Aug 07, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair sm2-pp3 valve, triton II filter. Upon backwash...sand is blown into pool. through air jets. System is two years old
Sounds like you have a problem inside the filter. This will probally be something you will want to get a pool guy for. If the filter is only two years old you should check for warrenty on the filter. Sorry for the bad news and good luck.
Mar 24, 2010 | Pool & Spa
When vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
Sand Dollar Filter
If sand is returning to the pool, the most common cause is the laterals, or the internal pipe is not connected to the valve properly.
If you have laterals with "slots" on one side and solid plastic on the other side, the slots have to be installed so that the slots face downward, toward the bottom of tank. If one, or more, are facing upwards, you are pulling sand right into the pool. If you have the newer laterals, with slots on all four sides, one, or more, may not be tightly in place.
If you have too much sand in the filter, that could cause this issue also. Pentair recommends using the #20 Standard Silica Sand in the filters.
Hope this helps!
Jun 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Mar 01, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward EC65 Extended Cycle DE In Ground Pool Filter System with Pump Logo
275 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
