Question about Xerox Phaser 7300DN Laser Printer
I have a problem with my Phaser 7300 it does not want to print on the screen it shows a message that says I need to change to image unit black which I did but it still shows the same message and still is not able to print. What can I do?
    New Friend:
  • 97 Answers
There's detailed information about how to reset the counters available here
Posted on Apr 11, 2011
  • 3 Answers
Reset the IU count. to do this Go into service diagnostics.Turn the printer off. Turn on again holding the "i" and "return" key down at the same time, then go into NVRAM and reset IU counts for Black.
Posted on Jul 24, 2010
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7760 only prints using black toner (no C, M or Y)
did you try adjusting the settings on the printer driver itself as in go to printers and faxes....right click on the printer and left click properties........under the advanced tab choose printing defaults and change the settings on the printer driver
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Cyan Imaging Unit Failure, U28 Error Code
the only thing I can suggest is to check the contacts that the imaging unit goes into, and i can also be the imaging unit itself. If i am not mistaken, you should be able to swap imaging units from another color just to see if the error goes away. But if this does not help, you will need to get it serviced. we have fixed these before, and its not a quick fix.
Apr 21, 2009 | Xerox Phaser 7300DN Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 asking for Imaging Unit
There is a spring on the waste section of the imaging unit that often pops off. When that happens it will not clear the replace imaging unit message. There is also a software patch on Xerox.com. Takes some searching to find.
Aug 11, 2008 | Xerox Phaser 7300DN Laser Printer
Too much yellow disbursing
Sounds like the yellow imaging unit it defective to be honest. I know its new, but may be bad out of the box.
May 20, 2008 | Xerox Phaser 7300DN Laser Printer
Replace Black Imaging Unit
My advice is to throw the printer out the window!! Just a suggestion!
Ted
Jan 30, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
