Question about Eddie Bauer 3-In-1 with Latch
Lost car seat instructions. How do I install facing rear? It looks easy enough but i want to make sure I'm not missing anything.
    Problem Solver:
  • 7 Answers
If it has a base and you car is equipped with mounting bracket there should be small metal hooks attached to canvas straps. Simply attach the hooks to the mounting points and tighten. If no mounting brackets you will have to remove the seat from the base. Pull the lap/shoulder belt all the way out, and on the base you should see plastic retaining slots. Weave the lap and shoulder belt through both sets of hooks on the base and pull tight. When the seat is mounted back to the base you should have very little movement when you wiggle the seat
Posted on Jul 21, 2010
Can i place the car seat facing front?
Hi - If it is an infant carrier Group 0+ carseat it must never be installed facing forwards. It is designed as a rear facing carseat to keep your child safe in the event of an accident. Always install a carseat according to the instructions.
Feb 21, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
Carseat manuals
download it from http://www.britaxusa.com/support/userguides.aspx?Key=5
Sep 16, 2008 | Britax Marathon
How to install front facing baby start car seat
Identify the parts. A car seat will likely come with two parts - the base and the actual cradle itself. The base part is what will actually be in the car, while the baby cradle (seat) is removable and portable - the baby cradle can be taken out of the car and easily attaches to most grocery carts (the front part where bigger kids sit) and restaurant high chairs (move the standard restaurant high chair upside down and you will have yourself a cradle holder).
Give it a try. Place the booster flat on the backseat of your car and run the seat belt around it to hold it down - read your instructions and they will have detailed graphs on how the seat belt hurts. Also look at your car manual as they will have special instructions and buckles for car seats
Get confirmation. Move your baby seat cradle on top of the base (remember, it always faces the rear, when your child is old enough you will have to buy a different type of car seat that faces forward towards you). With your hand, sternly move your baby car seat from side to side, if the cradle is easily swaying your car booster is not securely fastened. Remove the cradle and pull the car seat belt as snug as you can and try again
Get double confirmation. Call your local fire department and make an appointment to stop by - they will check and confirm your car seat is installed securely. Remember, this could save your child's life so 10 minutes with your local fire department is only a very small inconvenience!
Oct 20, 2010 | Baby Gear
Maxi-cosi car seat won't fix to EasyBase! Help!
hi chezfeaseys..here's a link for a manual..hope it helps..good luck!!!
http://www.instructions.maxi-cosi.com/download/cabriofix.pdf
May 12, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Eddie bauer rear/front facing manual
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Apr 16, 2008 | Eddie Bauer 3-In-1 with Latch
Jane Matrix Cup car seat
The best instructions I have found (as I have the same car seat!) were on YouTube. These instructions are really clear as they are in video format and they show you how to fit the seat in both the lie fat and rear facing mode.
In terms of the harness, you may or may not be aware that there a number of adjustments that can be made. The first is that you are able to adjust the positioning of the straps within the seat so that the child is not overhanging the seat. In addition the straps themselves lengthen by adjustment with the buckles on the straps.
I think all of these adjustments are in the instruction manual, which is available on line from the manufacturer if you have lost it.
Hope this helps!
Feb 08, 2008 | Baby Gear
Eddie Bauer 3-In-1 with Latch Logo
900 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
Douglas Dinnebeil
Douglas Dinnebeil
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
