Question about Gateway Profile 3 PC Desktop
My gatway profile 3 is not put the 32bit colour
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Colour management MP500
The printer profiles are in the printer properties tab either in the control panel under printing preferences, or in the dialog box that pops up when you press print, under advanced options and preferences.
Jun 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Colour Profiles for the Konica-Minolta BizHub C252P
For this type of colour output, such as InDesign you will really need a Fiery. This is professional colour running in Psotscript.
Without this you are going to have inconsistent results.
Depending on the Model will be how well it supports ICC profiles. the most recent "tuxedo line" comes with a profile downloader that works well with custom profiles.
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
HP 2600N LASER PRINTER
You can try going into your print settings/preferences and checking magenta only. printers you need to keep a watchful eye on your ink levels, because if you are out of ink, you can not print in ANY color, even black.
If the above thing not works You can begin by making sure you are not using anything above 24-bit colour (RGB) in Word.
Also: Word does not use a colour profile. It doesn't make any changes to
the colour, so it doesn't compensate at all. The only colour profile
between Word and the printer is your Printer's colour profile.
Hope this helps
Sep 19, 2008 | HP Color LaserJet 2600n Printer
Gatway entertanment center 3 yrs old
depends upon your ISP conection if you have "unlimited usage" then its fine
Jun 06, 2008 | Gateway GT5220 PC Desktop
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
Red printing
Hi... I have the same problem (Canon S500), however, I recongised that if one calibrates the screen and the printer with an external colour-measuring device in order to create icc-profiles, everything works a lot better. You can assign icc-profiles for devices in the Colour-Sync-Utility. However, you do not have to create the profiles yourself (it is better, but...); sometimes you can download them somewhere on the Internet. (quite hard to find though) Once you set up different profiles, the os translates colours a lot better between devices. Hope this was of any help...
Dec 11, 2005 | Brother MFC3820CN Print Server
Gateway Profile 3 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
