Question about Plumbing
Pump keeps knocking off. resets for a while then off again
  • 1,384 Answers
Look for your local pool pump motor repair shop with free motor testing.. could be a bad capacitor start or run .. need more info
Posted on Jul 21, 2010
What will happen if your knock sensor wire are not being connected and your error code p0325 keeps coming back after you reset the code?My truck is nissan pathfinder 1998 xe model.
DO NOT EVER change a knock sensor. It is a total waste of $600 and will do it again. It is not harmful to get this code. Usually, it means you have broken motor mounts, typically the right side. Do not use aftermarket, they fail quickly.
Jul 27, 2011 | 1998 Nissan Pathfinder
316 m reg, ran out fo fuel put some petrol in and now it will not start don't think the fuel pump is working is there a reset for the pump
Un firtunetly pumps with some age on them tend to lock up when ran dry. try hitting the bottom of the gas tank about in the center or where you think the pump may be. The vibration usually knocks them loose and they start pumping again. You might have to smack the tank 2 or 3 times. You will still need to replace the pump because they can continue to lock everytime you shut the car off. And eventually you wont be able to smack the tank to get it going.
Jul 03, 2011 | BMW 318 Cars & Trucks
How can i manually reset the computer on my 99 chevy silverado 1500 4x4? my oil pump is weak and it has a dry start and when i started it this mornin i think it kicked the knock sensor and shut my motor...
The knock sensor will not cause a no-start. The knock sensor only retards the timing when the engine is running. If the starter is not working we need to check the battery voltage, battery cables, starter, engine ground, neutral safety switch, ignition switch, security system. These are the only things that can cause a no crank.
If you really have the urge to clear your computer disconnect the negative battery cable for 10 minutes.
Mar 10, 2011 | 1999 Chevrolet Silverado 1500
MY BJ 505 KEEPS KNOCKING OUT POWER AT HOME... AFTER I RESET THE TIMER BY TURNING THE DIAL ... IT RESETS AND POWER IS OK FOR A COUPLE OF HOURS UNTIL IT HAPPENS AGAIN
Are you talking about resetting the defrost timer? I would check to see if the defrost heater is shorted out tripping the breaker when it goes into defrost mode.
Apr 30, 2010 | Refrigerators
Engine check light keeps coming on and stays on.i had the car diagnosed the mechanic said that the knock sensor is dad and i need to get a new knock sensor so i bought a new knock sensor put it in and it...
did you have the check engine light reset after replacing it? if not then go to auto zone, and let them know you replaced it and need to reset the trouble light for the check engine light... hope this helps...
Apr 14, 2010 | 1995 Toyota Corolla
The oil pressure gauge keeps dropping down to 0 while i am driving
If you don't hear any ticking or knocking while the pressure gauge drops, the problem is probably a failing "oil pressure sensor". If you do hear a ticking or knocking, the problem is probably a failing "oil pump".
Jun 03, 2009 | 1997 Jeep Grand Cherokee
I have new Bosch dishwasher..lassic electronic....the check water level keeps coming on because water is not pumping out....tried to reset and it still willnot pump out....any suggestions
check the drain connection.....if it is connected to a garbage disposal make sure the drain plug knock out is removed otherwise the dw will not drain. Also make sure the drain hose is not pinched or kinked.
Aug 02, 2008 | Dishwashers
Plumbing Logo
32 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
