Question about HP LaserJet 4200dtn Printer
Where do you find where to put the ip address in a laserjet 4200dtn
    Scholar:
  • 117 Answers
Click on the down button on the printer. Go to "Cinfigure Device" then click the green button. Then click on the down button to "I/O Menu" in here you will click on TCP/IP then click on "enable" then you will move down to Config Method You can then select BOOTP(automatically assigns and IP Address) or DHCP Manual (where you set the IP Address, Subnet Mask, Default Gateway).
If you go to the I/O and there is no TCP/IP selection then you will need to purchase a Jet Direct Card from somewhere.
Posted on Jul 21, 2010
How set IP adress for printer HP LaserJet 4200
To configure the Jetdirect card in your HP printer so it works as a network printer, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jun 25, 2011 | HP LaserJet 4200dtn Printer
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
HP LASERJET 4200DTN IS CRUMPLING MY PAGES AND THE INK IS SMEARING DOWN THE LEFT HAND SIDE OF THE PAGE
hi
it sounds like the fuser needs replacing and the rollers need replacing
by maintenance kit , HP p/n Q2429A
if you are in Toronto, call Motion Technology Solutions, 905 266 9884, ak for Frank
Apr 18, 2011 | HP LaserJet 4200dtn Printer
I have a laserjet 4200dtn with a new cartridge installed. There are no message errors when i print, however it prints the first couple of inches very light and the about one inch from the bottom it...
Hi is this fault new (the machine was working fine until you put the new toner in?
if yes it was fine then It must me the new toner send it back and get a replacement
I repair this model and I dint recall ever coming across this fault.
good luck Ian
Mar 15, 2011 | HP LaserJet 4200dtn Printer
How do you print double sided with the HP LaserJet 4200dtn?
if the machine has a duplexer, it will print both sides
Jan 14, 2011 | HP LaserJet 4200dtn Printer
What is the default ip address of the printer hp laserjet 4250n?
There is no default IP address on HP printers with Jetdirect print server card.
You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range.
To configure the HP network printer to work on your network, please click on this link and follow my instructions :-
Dec 14, 2010 | HP LaserJet 4250n Printer
Our hp 4200dtn jams frequently and often spits out several blank sheets. when it jams, the error message reads "unexpected size"
Make sure the guides for width are snug, and also "fan" the paper before putting in the tray
You might also try a heavier paper or different brand as a test.
Oct 09, 2009 | HP LaserJet 4200dtn Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
May 10, 2008 | HP LaserJet 2550Ln Printer
HP LaserJet 4200dtn Printer Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
