Question about Samsung SF-5100 Plain Paper Laser Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know that i have installed it correctly therefore this is not the first time I am changing the ink. Can somebody please assist me. Thankyou
  • 241 Answers
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Posted on Jul 21, 2010
How to cahange ink, samsung powerful 3-in-1 inkjet fax sf-350
there is a button on the front pannel. change ink. press it. open the front pannel. take cartride out and put new one in. close front panel. printer will ask if it is a new or old cartridge. 1 for new 2 for old.
Sep 12, 2011 | Samsung SF-330 Plain Paper Inkjet Fax
I hav ainstal sf 565 new toner machine saying toner is emty what idu?
As soon as you installed it, you prompted a change in the ink levels which will AUTOMATICALLY pop up on your screen when you are properly connected and attempt to print something. That is when you tell the system that it is a new cartridge. OR YOUR PRINT HEAD IS CLOGGED Brother printheads are very easily clogged with air bubbles so there is very high risk that refilling ink will damage your printhead. It is not worth it to save money on ink and wind up with danmaged or totaly nonfunctional printheads.
Jan 29, 2011 | Samsung SF-565 Laser Fax
I have installed a refillid cartridge into Samsung fax machine SF-375TP and I get message"Install ink cartridge".What must I do in order to get machine to start working again?
Many cartridges DO NOT respond well to being refilled, and if you don't use a manufacturers ink cartridge. And if you don't you will get that message.
Sometimes you can reset the "Chip" in the cartridge, yes, there is one in there too, especially so it cannot be refilled by a third party,
There is NO simple way around this, "They" want you to buy NEW inks each time, and NOT refill, it sux huh?
www.crowson-ward.co.uk/media/pdf/Samsung%20SF375TP.pdf
Manual above.
www.futuregraphicsllc.com/lit/instructions/CLPCRSTECH_ud.pdf
Above is a link on resetting the cartridge.
Aug 04, 2010 | Samsung Office Equipment & Supplies
Do i need an ink cartridge for the fax machine to work and setup
Some brands of fax machines and all-in-one printer/scanner/fax/copiers need the ink cartridge to be present and have some ink in it to perform functions which don't actually require ink.
My dad bought a Brother all-in-one, and he is unable to scan or send faxes unless he replaces an empty ink cartridge first. If you have a Brother fax machine, I'd suggest returning it and buying a different brand. They waste ink on unnecessary cleaning procedures and force you to buy more for stuff that doesn't need ink.
Mar 03, 2010 | Samsung SF-3200 Fax
How do you change the ink cartridge on samsung sf31oo
Hi
It's very easy to remove the ink cartridges of Samsung printers. I have provided you the link to download and see the manual of the printer you are using, please go through the weblink and you can easily remove the ink cartridges.
Here is the weblink
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06011300&prd_mdl_cd=SF-371P%2fXIP&prd_mdl_name=SF-371P
Jan 28, 2010 | Office Equipment & Supplies
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
I need some help installing new ink cartridge
press the button that says either cartridge or cartridge replacemant on left side i think then the cartridge moves to middle then replace it and press button again and select new
Dec 05, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Receiving faxes
tHE INK SEEMS TO HAVE FINISHED, DOES THE DISPLAY SHOWS,-INK LOW OR EMPTY, REPLENISH THE CARTRIDGE AND THE FAXES WILL BE PRINTED FROM MEMORY.. HAPPY FAXING OMNIPRESENT
Aug 24, 2007 | Samsung SF-4700 Plain Paper Inkjet Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
897 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
