I have plugged my laptop into a projector using the blue video cable. i have pressed fn F5 but nothing is happening. Helpp
    Problem Solver:
  • 13 Answers
Thats OK if the socket is blue on the ones we use in class it is a D15 or VGA lead, most of the projectors will also take a yellow to yellow plug but don't have any connected that way, HDMI leads can be used on the more modern lappies and projectors OH! and we have to have the projector on when we press F5. Good luck, John
Posted on Jul 21, 2010
I have hooked up my computer to the projector. I get the blue screen and nothing else. How can I get the image to project? Thank You!
make sure you're on the correct source on the projector. now i'm not sure if you're using a laptop, if you are, then you're gonna have to press FN and F5 (depending what type of laptop you have, sometimes it's F8) buttons on your laptop. this activates the computer port of your laptop.
May 23, 2011 | NEC MultiSync LT81 Multimedia Projector
I cannot switch to my projector with this notebook. I held down the Fn key and then I pressed F5. What else am I suppose to do
what kind of projector are you using? what color are the ends of the cable you are connecting your projector to the laptop with? if your using the Blue ends, be sure your projector is on, and is running on the VGA input. Most projectors do not auto detect input and must be set manually prior to the FN + F5 key combination. White connector ends are called DVI or Digital input on the projector.
Sep 02, 2010 | Acer Aspire One PC Notebook
Can't get my notebook screan to show
hello,
Indentify the video output options of the computer and the input options of the projector. Most common are VGA and S-Video. use the appropriate cable to connect the two. Your projector may be able to probe its ports to see what signal it is getting.
On your computer. After you make the hardware connection and your projector is set to receive on the correct port, extend your desktop to show on a TV if S-Video, or on a monitor if VGA. To have the screen of your computer to appear on the external screen, use the FN-Fx key combinations. Examine the laptop`s function keys and look for some icon that shows a computer and a screen. Most probably it is the F5 key.
Assuming F5 to be the right key, you press Fn-F5 and an OSD will appear on your computer. You scroll from an icon to the other by pressing F5 while still pressing down the Fn key.
If that does not work, I suggest you check your computer s manual for the right key combinations.
Hope it helps.
Oct 02, 2009 | HP VP6310 Multimedia Projector
My laptop won't recognize a projector
You need to push the function key FN and hold it down then press F5
Aug 20, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
Jun 13, 2009 | Lenovo M500 DLP Projector
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Acer extensa 5620Z laptop running XP. function/F5 key does not work to switch from monitor to projector display. Any suggestions gratefully received.
Plug in the Projector before pressing FN+F5
(Just in case your not sure, you have to Press and hold the "Fn" button near the "Ctrl" button and then press "F5")
Try again
Oct 07, 2008 | Acer Computers & Internet
How can I view my Del Laptop screen on my 50" Insignia TV?
do you have the connector.to connect both the units.
Aug 29, 2008 | Televison & Video
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
