Question about Daewoo Refrigerators
Fridge not cold enough and freezer not producing ice cubes
My daewoo fridge freezer FRSU20DCB is not producing ice cubes and the fridge is not getting cold, i've been quoted £199 to look at it and fix it!! What could be wrong with it and can i fix it?
  • 4,793 Answers
How does any tradesman(person) know how much its gonna cost before they even look at it.....
i would suggest you call a small,family run,electrical shop.
they have a reputation to uphold......
Posted on Jul 21, 2010
  • 2 more comments
  • robeasson Mar 22, 2011
    hello dinxtheminx,
    it most definately is the freezer fan in the rear top of the freezer compartment .
    If your warranty has ran out the replacement fan can be purchased of daewoo spares if you are in my area i can replace the fan at a lot less than two hundred pound
  • geoff hunter Mar 22, 2011
    Rob,this post was made in July and maybe they got it fixed at the price quoted,,,,,,.suckers.
    should have taken the advice given and gone to a proper tradesman.......
    geoff.
  • simeon ereira Dec 29, 2012
    rob, what area are you? we have the same problem!! if we order a fan, how much would you charge to fit it?
  • Catherine Winston Mar 07, 2013
    Hi i have the same problem. I noted that the fan at the back of the fridge is not working so i will assume this is the main problem. Any chance someone might be able to help me solve this problem? thanks for any help
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Hi i have installed my american fridge freezer DAEWOO FRAQ19DCB but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to t
The inlet water supply solenoid valve has two coils and valves. The icemaker valve is not functioning either electrically or mechanically. Best bet is to replace the complete assembly.
Jan 25, 2015 | Daewoo Refrigerators
Daewoo FRSU20DCB not making ice
Sounds like you have an airflow issue. Freezer temp. should be @10-15 below and fresh food area @35-37 above zero You may have an evaporator fan or door switch failure
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
This link can help you diagnose your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 23, 2017 | Daewoo Freezers
So why does it take so long for the fridge to produce ice, and why after being turned on for 5 hours from new is there no water in the ice tray? The water runs via the water dispenser so why is it not in...
first, why are you asking a question on fridges in a section about cars specifically Daewoo.BUT to answer your question......a fridge/freezer needs about 24 hours for the whole system to settle down,and reduce the internal temp BEFORE it makes ice,
Nov 10, 2010 | 1999 Daewoo Lanos
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
1,720 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
