Question about Symbol MC9090 Mobile Computer Portable Terminal
MC9090 connection problems vs. MC3000 and WT4090
Hello, we are using in our warehouse area together with extreme networks APs motorola mc9090, mc3000 and wt4090 scanner. All scanners use TKIP encrpytion. But just mc9090 scanners have the problem to keep the connection solid. They lost their connection and the user must re-log to the network. The other two mentioned scanners are running without any problems. Any idea?
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
  • 12 Answers
SOURCE: How do I change the sleep timer settings on a Motorola MC9090
A - From the Windows Mobile user interface:
1. Tap Start (the Windows Logo), then Settings.
2. Tap the System tab.
3. Tap the Power icon.
4. Tap the Advanced tab.
You can change the number of minutes before power is turned off when on battery and when on external power from there. You can also uncheck the "Turn off device if not used for" check box to disable the timeout entirely.
B - From the registry (useful for deploying the setting as a .reg file to the device, in case you have many MC9090 guns you are supporting or you are wanting to set it to a value the user interface does not support):
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout"=dword:00000000
"ACSuspendTimeout"=dword:00000000
The above values are in hex and represent the number of seconds before timing out when on battery or AC power. For example, to set the BattSuspendTimeout to 180 seconds, you would set it to dword:000000B4. To disable it entirely (the equivalent of unchecking the checkbox in the user interface), set the value to 0.
Thanks,
Brad Radaker
Radicomm, Inc.
(makers of QuickTalk - push-to-talk over WLAN for MC9090)
www.radicomm.com
Posted on May 13, 2009
  • 31 Answers
SOURCE: Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Posted on Jun 30, 2009
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
Motorola mc9090 out of memory on start up
It is best to contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
Jun 13, 2014 | Zebra Symbol MC9090-G Portable Data...
Function keys on MC9090
hi,
Sound like you need to look at your Keyboard mapping files, easiest way to fix this is to use Motorola System Configuration Manager - Downloadable from the Motorola website.
If the unit need to be restored to factory defaults, than a fast way is to run the Clean boot files from the SD Card also downloadable via the Motorola site - search for 'MC9090 Clean boot'
Mar 04, 2013 | Symbol MC9090-G Barcode Scanner
Upgrade RAM on Symbol/Motorola MC9090 to 128MB
Sure, we can upgrade any and all MC9090 products from standard memory of 64/128MB to 128/128MB. Please contact us via email or phone.
andrewk@diamondbarcode.com
main 847-847-7835
cell 847-815-2230
Mar 14, 2012 | Zebra Symbol Technologies MC909X-G Series...
I have 5 scanners and 3 access points in my warehouse and the scanners only stay connected when I only have one access point turned on and the scanners set to connect to that access point (Mandatory), then...
Hi, that is happening because your 3 APs have the same fixed IP address. you have to change the ip address on 2 APs, right now it seems to be that your 3 APs have the same fixed IP address, for example in my warehouse, for AP #1 is 10.20.40.30, for AP #2 is 10.20.40.31 and for AP# is 10.20.40.32 hope it helps!!
Dec 06, 2010 | Symbol MC9090 Barcode Scanner
How do i update the firmware on a Symbol MC9090?
http://support.symbol.com
go to the link above, type in the vs of the mc9090 that you have, for example, firmware upgrade for mc9090-g
let me know if you need anything else
Kim Ganoe
Datex Corp
800.933.2839
Mar 18, 2010 | Symbol MC9090 Barcode Scanner
How do i restore mc9090 to default?
Hello sburrell. By reset to default, do you mean reinstall the Operating System and completely start over? If so, just contact Motorola/Symbol or the vendor you purchased the unit from and get the exact Operating System type and version for your MC9090. Then you can download the correct OS installer from Motorola/Symbol. The packages come with a "readme.txt" that will instruct you on how to install the OS. I hope this helps. Good luck!
Dec 14, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Symbol MC9090 unable to connect to wireless network...
check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Jul 29, 2009 | Symbol Motorola MC9090 Mobile Computer
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Mobile Computer Portable Terminal Logo
378 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
