Question about Sharp 56DR650 56" Rear Projection HDTV
DO I NEED TO REPLACE THE BLUB OR THE COLOR WHEEL?
I HAVE A 56" DLP SHARP MODEL 56DR650. IT WILL WORK FINE FOR A COUPLE OF HOURS AND THEN IT WILL BEGIN TO FLICKER? I THEN TURN IT OFF AND THEN TURN IT ON AND IT WILL BE FINE. DO I HAVE TO CHANGE THE BLUB OR THE COLOR WHEEL?
  • 2 more comments
  • toroneza Apr 29, 2008
    I've owned the same sharp 56" model 56dr650 for a little over a year and I'm too noticing flickering that very noticeable on the left side of the screen.
    Bulbs go for as little as $150 including shipping and handling.
  • Warbadjer May 13, 2008
    I have the same exact problem as above. Television is on for about an hour and then the screen goes nuts. I replaced the bulb with a new one. It worked for about fifteen minutes longer than the previous bulb, but then started flickering AGAIN. Frustrated.....Any ideas?
  • Anonymous Sep 22, 2008
    I have the same problem! the tv will flicker blue and then the picture in to what looks like old school nintendo graphics.. is this a bulb issue or what cause the solution here isn't very helpful
  • Tim Harvey Mar 09, 2009
    I am having this same flickering problem, will be a good picture for about an hour and flickers and colors go kinda funky. turn it off and possibly.... let it cool ?...and then its ok for about an hour
    the bulb is new and it did start the whirring noise about a month before this
  • 4 Answers
Posted on Feb 22, 2009
The Color wheel is the culprit-loud humming is the motor. Sometimes you can clean the silver reflective band on the wheel and the clicking-color shifts will stop, but replacing the wheel is the best solution. On ly replace Lamp when instructed by the hour counter warnings or if it does not light anymore. Sharp and other companies should help fix this, but they won't.
Posted on Oct 27, 2008
How did you get sharp to replace it for free? everyone review I have read so far says Sharp is not helpful at all...humming noise has been driving us crazy for two years...just came on with a "FINAL WARNING: REPLACE THE LAMP IMMEDIATELY"
Posted on Sep 16, 2008
Posted on Apr 28, 2008
Need to clean color weel
Hello
To clean the colourwheel do the following.
Soak cotton swab in denatured alcohol
Using a circular motion, swab gently one color area at a time
Use dry swab to remove film build up.
Repeat to ensure the wheel is thoroughly cleaned
DLP color wheels need to be cleaned approximately every six months to a year, if the environment they are placed in is smokey, greasy or dusty. Sometimes, restaurant owners or places with high customer traffic will find that their TVs are experiencing picture degradation due to the smoke-filled rooms or greasy fumes from kitchens. There is no need to replace the color wheel but just to do a quick cleaning to save money on replacement parts. Even if you have your TV at home, your DLP color wheel may require a cleaning occasionally to provide clean picture quality.
Mar 27, 2011 | Sharp 56DR650 56" Rear Projection HDTV
Loud Buzz
loud buzz is the color engine, turning the color wheel. Find instructions on how to take it out and clean it and that should fix that problem.
Jun 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Sharp dlp 56dr6509 glass
That little glass only comes with the light engine. Not Available from parts distributor. Try Harding Glass or any other glass shop. They maybe able to supply if they would bother with asuch a small sale. Did you work on the Color wheel?? Dan@DBS pentad99907@mypacks.net
Dec 30, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Picture fine for 10min.-then flickers(clicking sound)& then colors gone yellow
Looks like it's a color wheel problem-found a cleaning walkthru online, but it doesn't get rid of the loud hum form the CW motor. Also, it is thermal related-when the colors went out I placed a fan next to the color wheel and everything went back to normal. Several design flaws here and for $3000 these companies should do better-severe problems after a couple years is not acceptable.
Oct 26, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Color Wheel
ebay has them for like 250.00.
Jun 14, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I have the color wheels in stock let me know if you need them
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
272 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
