Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
Installed Microsoft Office 2003 and now can't attach files to fax I am using winfax pro 10.03
    Sergeant:
  • 269 Answers
Are you on win 7?
write back, i have included the below in case you fall into this cattegory
Don’t get duped into buying a counterfeit WinFax PRO 10 CD ROM. Here is how you can tell the difference from a “real” CD ROM and the obvious fakes. If you purchased your Symantec WinFax PRO with a box and manual, chances are it is the genuine item. If you purchased a “loose” CD ROM, usually referred as “OEM”, then you should check for the following:
How to detect a counterfeit WinFax PRO 10 CD ROM
  • Symantec never included the actual revision of WinFax PRO 10 (10.01,10.02 or 10.03) on the CD ROM. So, if your WinFax PRO CD ROM says “WinFax PRO 10.03′ its a fake. All genuine WinFax PRO 10 cd’s contain the heading ”WinFax PRO 10.0′
  • If you see text with “winFAX” or “Live Update” anywhere on the CD its a fake. The official Symantec trademarks are ”WinFax” and “LiveUpdate”, no other variations of this text should appear on the CD ROM.
  • Failure to capitalize ”symantec” and “corporation”.
  • An “All rights resverd” spelling error, or other spelling errors.
  • Incorrect font used for WinFax PRO and Symantec logo. The current Symantec logo is consistant across all software they produce.
  • Silver portion of CD is a (dull) matte finish, on the real CD it is relective (mirror surface).
  • To determine if the CD is brand new and sealed – geniune WinFax PRO 10 CD’s come in a white envelope sleeve that are sealed with a sticker that may have one or more of the following: a bar code, a Symantec 5 or 6 digit product code, a brief license agreement.
  • In most cases, manufacturer information is printed on the inner rim of the CD ROM of genuine CD’s. This is usually missing on a counterfeit.
  • Update patch 10.04 is not included on genuine CD ROMs. Any CD that contains the patch update to 10.04 is a counterfeit
Posted on Jul 21, 2010
  • 143 Answers
If you installed Windows 7, you won't be able to attach files with WinFax PRO. It is not compatible with Windows 7. For more information you should visit http://www.getfaxing.com
Posted on Jul 28, 2010
SOURCE:
Winfax hangs up after receiving the first two pages
I use win fax pro to receive and the sender use Epson fax equipment. I can receive 2 pages when the sender send continuously.Although I can see 2 pages success message in the inbox,only can see the second page when I double click this message.Surely is I receive 2 pages because this receive message file size is 54kb i.e 2 normal pages for our office daily use size.
Aug 08, 2012 | Symantec WinFax Pro for PC
Dear Sir I cant attach any file to my fax. When I press bottom to attach a file, there is nothing.
WinFax PRO requires Windows XP or earlier operating system. It is not compatible with Windows 7 or Vista, therefore, you cannot attach any documents with these operating systems.
http://www.getfaxing.com/forums
Jan 31, 2011 | Symantec WinFax Pro for PC
Have re-installed WinFax Pro 10.03. At every system start up WinFax install program appears even though it's installed. Also when I attempt to Insert file from Word 2003 in the fax, I get an error message...
Goto "Start" in windows select "RUN" type in "MSCONFIG" press ENTER, Select "STARTUP" tab uncheck the winfax then select apply then OK. Now restart your PC, u should not get this problem now.
May 24, 2010 | Symantec WinFax Pro for PC
Windows Updates will not download...
Version 10.04 will not fix the problem with Windows Updates, and 10.04 will only update from a 10.03 version. Its not recommended unless you're using Fax Sharing and Windows XP.
Its possible you've overwrote some important system files in the process of copying files, but WinFax itself would not cause the problem.
Feb 07, 2008 | Symantec WinFax Pro for PC
WinFax Pro 10.0
I don't know the Operating system you are using but that version, as I remember, had a few problems. Suggest you check to A) make sure it's fully compatible, B) Check the supplier site (Symatec I believe) for issues...(under support), and C) If all else fails uninstall and reinstall. Use Ccleaner to clean the registry before reinstalling (free and you can't make a mistake) and also delete the application folder (typically under program files in an automatic install). Do the latter after using the windows add/remove programs capability. This should do it. If not bug me.
Tango.
Feb 04, 2008 | Symantec WinFax Pro for PC
WinFax Faxes Trouble!
Hello, I dont not use this program due to the problems it has. go to http://free.grisoft.com/
It's free
Nov 16, 2007 | Symantec Winfax Pro 10.03 (winfax10.03)...
Receiving Fax Line always 'busy'
Installing fax software can be tricky, particularly if you want to import phone-book listings from an existing database or PIM, such as Microsoft Outlook. But WinFax Pro proves easy to configure. A series of introductory screens walks you through installation; you just click Next to accept the default configuration. In our tests, WinFax Pro accurately detected our fax modem and seamlessly imported our contacts from Microsoft Outlook. By comparison, competing fax programs either don't import directly from Outlook or make the process trickier than it needs to be. you can try to look on website and there will explain to you. http://reviews.cnet.com/e-mail/winfax-pro-10-0/4505-3536_7-1536745.html
May 28, 2007 | Symantec WinFax Pro 10.0 for PC
How To Import Individual WinFAX files? .FXR and .FXD
Hi You can go to:: http://www.getafreelancer.com and post this request. I've seen it there before you wil need some third party app. Look for Project Number 138099 this will give you more info. Have a Great Day!!
Apr 12, 2007 | Symantec WinFax Pro for PC
Winfax pro problem
This is a solution that was suggested for an earlier edition of the Winfax Pro, but there is no reason why it shouldn?t work on this one as well: 1. Close Winfax and any other program that has anything to do with it, delete all the temp files that yo don?t need. 2. Run Scandisk and fix any problems that may come up. 3. Run delfix.exe which is located in the winfax folder in the status files. 4. Run delfix-rebuild and delfix-optimize and check if the problem is solved. If the problem reoccurs there is another possibility- to change the name of the WinFax\data folder and create a new one which you will transfer the address book file, status files etc. from the old folder. Note that there might be some information that wouldn?t go through.
Feb 22, 2006 | Symantec WinFax Pro for PC
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
239 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
