Question about Crosley 1950 Pay Phone
Hi i have an old wall mount phone hook up the
Hi i have an old wall mount phone hook up the kind where you push the phone on the mount and then slid it down over two pins. How does the Crosley payphone connect to the wall? thanks ron
Receiver falls off the phone when using wall mount? Help
The wall mount is supposed to have a protrusion which engages the receiver. make sure it is in place of make one and glue it on.
Sep 24, 2014 | NEC DTU-16D-1 Display Telephone
The instruction manual does not include instructions to use this as a wall-mounted phone.
Hi..
There will be any instructions regarding a wall mounted phone unless it is of that kind.... It the mobile that you have can be used as a wall mounted , and still instruction missing. kindly send the model number of your phone. and i shall guide you through
thanks for rating
May 30, 2011 | Cell Phones
Hi. I have an old Sony Wega 32" LCD TV which I
ok it depends on the wall mount but this is the basic idea of it. make sure there is at least one other person to help you.
1. Make sure everything is off and unplugged from the tv. 2. If you have cables holding your tv to the wall remove them. 3. there should be securing screws at both sides of the arms attaching the tv to the wall. loosen them/ remove them. 4. lift and pull the tv away from the wall. have a friend help you. 5. remove the screws and bolts from the tv and the wall mount and you should be done.
If this doesn't work, find the manual for the wall mount. if you need help or additional tips put them in the comments. Thanks
May 26, 2011 | Sony Televison & Video
Television set is roughly 18 months old and has only recently been wall mounted The picture started to freeze then the following day it wont come off standby Brand EVOTEL
HI, if the problem started straight after the wall mount i would imagine the screws holding your wall mount bracket to your tv are the incorrect ones and will be too long ! this could cause all manner of problems ,on the back of your tv there will be numbers by each mounting hole you can safely use ,these will usually have 8mm or similar written in the plastic ,so use no screws longer than what it states or the tv can break down easily ,check the screws holding your tv mount on ,hopefully it will come right if you put the correct screws in. Thank You for using FixYa
Feb 10, 2011 | Televison & Video
How to hook up a engine temperature guage.
After market ---  Electrical or Mechanical? If you have a A/M Mechanical this is easy.Find where you want to mount it, in side the cab. run the sensor tube out to the eng. bay. thru the fire wall. Find a place on the engine head any where you find a plug that is the same size as the fitting in the kit. Drain coolant and install your sensor tube. Some come with lights, find your fuse to your running lights and push your gage light wire in next to the fuse and your done. Sim. if dealing with a electrical gage- Mount your gage, run your wiring out thru the fire wall out to the sensor fitting, drain coolant mount your sensor wire it up. hook up the light same way.
Aug 04, 2009 | 1983 Ford Bronco
Trying to replace regular phone mount with a wall mount
If your just changing the jack to a hanging type, the fix is easy. You remove the old jack, replace with new one connecting the original wiring...red/green or blue/white.
Apr 16, 2009 | Lands Phones
VoIP Modem Problems??
the line coming in from your old provider of phone is causing your problem, I am a phone tech for cable company and I find this all the time . your old phone provider if still hooked uo is push a small amount of voltage onto your in house wireing even though it does not have dial tone. just unhook your test port on the old interface and this should fix your problem .dsl filters will also cause a prblem , make sure all filters are removed.
Jan 22, 2009 | Computers & Internet
I need to mount my 27" on wall.
If you still need the wall mount for the astar ltv-2701 call me at 323-7676-6030 I will help you look for it.
Jan 18, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
Wall Mounting
Slide it all the way up and out, turn it upside down and slide it back in.
Sep 06, 2008 | GE 29267GE3 Corded Phone
Crosley 1950 Pay Phone Logo
59 people viewed this question
Top Crosley Lands Phones Experts
Marvin
Marvin
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
