Question about Philips Standard 104S 14" cRT Monitor
Monitor keeps blank even the power lLED is on green
Hi I have a problem with my monitor CRT 14" 104s. I use it for quite time. Now when I starts the computer the power light goes green but no display appear on screen. I replace with same monitor to check and the video is working fine as usual. Then I replace the power cable and fixed it again and some times the picture comes. i tried this when I got this fault every time and sometime I have to keep fixing the power cable for hours to take the display. suddenly the picture appears. I tried with replacing the power cable and cleaning and adjusting the three power pins in the monitor also. So it's still bugging me. Please give me a good workaround for this.e-mailsahanpere@gmail.com Hi I have a problem with my monitor CRT 14" 104s. I use it for quite time. Now when I starts the computer the power light goes green but no display appear on screen. I replace with same monitor to check and the video is working fine as usual. Then I replace the power cable and fixed it again and some times the picture comes. i tried this when I got this fault every time and sometime I have to keep fixing the power cable for hours to take the display. suddenly the picture appears. I tried with replacing the power cable and cleaning and adjusting the three power pins in the monitor also. but monitor working under DOS mode it is ok please give advice for repair hwkarunaratne@yahoo.co.uk
    Problem Solver:
  • 5 Answers
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Posted on Apr 23, 2008
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
My monitor is not working sometimes
i think that problem from eht [fbt] trasformer. i also.face that problem
Jan 29, 2008 | SAMTRON 55V 15" CRT Monitor
HP mx705 17 in.CRT --Blank monitor
I assume the monitor is still plugged into the back of the system?
If so, do you get any beeps which can denote error codes for the system?  Put your ear to the monitor, any strange whinning noise?
Oct 22, 2007 | HP mx705 17" CRT Monitor
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Oct 23, 2006 | Philips 105S51 15" CRT Monitor
Philips Standard 104S 14" cRT Monitor Logo
183 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
