Question about Refrigerators
How to change bulb in lec fridge r450cw - Refrigerators
My LEC T5029W is set to 1 however food in refrigerator is frozen -10 degrees C?
one is the coldest setting
set it higher say about 1/2 the adjustment of the knob
Aug 03, 2016 | LEC Refrigerators
LEC Tn216 Fridge Freezer is freezing my food
is that not what freezers do . read you manual and adjust the temp settings
Apr 27, 2015 | LEC Refrigerators
How to fix lec l5026w fridge on top of freezer?
There should be brackets that would attach to the back of both to hold them together and in place, similar to a stackable washer and dryer
Sep 07, 2012 | LEC Refrigerators
Replacing door interior light switch of under counter LEC fridge
If it's the rectangulat one, it prises out of the hole with a flat screwdriver. Make sure it's unplugged before working on it. Do you suspect a faulty switch?
Apr 24, 2012 | LEC Refrigerators
I have a lec r450w fridge and the internal bulb needs replacing. There does not seem to be an obvious way to get to the bulb. Do i need to unscrew the temparature control dial to open the panel ?
No, you dont need to touch the temperature control knob. You access the lamp and lampholder from underneath. Get a small thin screwdriver, slide it up the left-hand-side of the opaque plastic (that allows the light to shine through into your fridge). Prize it down, it is not brittle so it should not snap. the opaque cover will come out and the bulb is right there to unscrew. the cover goes back in easier than it comes out, so just reverse the process. Make sure you isolate power to the fridge before you begin.
Aug 01, 2009 | Refrigerators
Fridge Light Needs Replacing
I am going to leave it as it is and get a new fridge later.
Nov 20, 2008 | Refrigerators
Refrigerators Logo
707 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
