Question about A & A Manufacturing Ramsond 40D Plasma Cutter Inverter
I was using drop cord may have been to small to carry the loadit wasnt performing right it just went dead hasnt worked again .power switch licht comes on but the oc light doesnt thanks steve
  • 25 Answers
Does the cooling fan come on?
Posted on Oct 21, 2010
My car hasnt been ran in a while so bought a new battery starter and spark plug wires It started but putted a bit so thought well its been a while But while driving down the road I noticed my speedometer...
its possible, however I would recheck the wires that you replaced and be sure that they are in the proper order, an improperly routed ignition wire can cause a lot of the things you have just discribed.
Feb 24, 2014 | Cars & Trucks
No display after installing Biostar motherboard
THE DRIVERS MAYBE ? .
THE MONITOR ? .
YOU HAVE TO EXCLUDE ONE THING AFTER ONE OTHER.
Jun 13, 2013 | Biostar Computers & Internet
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Motor starts and stops-replaced pressure switch
The motor may be overheating causing the thermal switch to drop out. This can happen if you are using a small gauge extension cord
Nov 06, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
Service engine soon light came on and later that day turned off
The reason for the light to come on an the after you have switched the vehicle off and back on again and the engine light stays dead is because the control units of the vehicle will reset when the ignition is switched off for 10sec. If the light stays off the it might be that the car got a wrong reading from a sensor and caused the engine light to come on. If it was a serious problem the light would have come on again
Apr 03, 2009 | 2006 Mitsubishi Lancer Evolution
Car will not turn over dead no sound
It seems as if you have had a major electrical short in a main power circuit, for this to happen.I would take it to a auto electrician and have a test carried out.
Dec 16, 2008 | 1997 Mitsubishi Mirage
Power and speaker cables
Most electronic stores carry these, radio shack, circuit city, best buy. One thing, when buying the power wire, make sure the guage is right for the wattage.. to small of a wire may hinder the performance of the amp.
Ciza
Oct 31, 2008 | MB Quart RAA2400 Car Audio Amplifier
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Mach 3 cyclone hoover vac
I have a MACH 3 Cyclone that is only a few months old that just suddenly stopped working and went totally dead like there was no power going to it.
I tested the power switch and noticed that there was no power running to the switch.
I then noticed that the switch sat on top of a very long adjustable handle so I figured I would check the pwer connection at the base of the handle.
1) I unscrewed the 2 screws closest to where the power cord goes into the vacuum.
2) Pulled the small blue cover partially out (it wouldn't come out all the way)
3) I found that there is a power cord (looked like a really small extension cord) that runs through the inside of the handle. Adjusting the height of the handle must have made it come uplugged at some point. I plugged this cord back in.
4) I reattached the small blue cover and screwed the 2 screws back in.
This fixed the problem.
I am willing to be that this is a common issue with this vacuum cleaner. Its a 5 minute very easy fix and strongly suggest checking this if your vaccuum suddenly goes completely dead without warning.
Dec 11, 2007 | Washing Machines
Presario will not start
Hi, remove the left side of your case, turn on power and see if you can see a red or green led light on the board, if its not showing then your power supply is faulty. If the light is on then with the power off check the RAM chips are tight. if that does'nt work Then trace the cables from the front of the case, locate which is the pwr switch and unplug that, turn the poweron and then use a small screw driver and bridge the pins of the pwr switch. If this does not work you have either a dead CPU or a dead motherboard. Regards mistyman
Oct 07, 2007 | Generic Memory Compaq Presario SR1215CL by...
A & A Manufacturing Ramsond 40D Plasma Cutter Inverter Logo
97 people viewed this question
Top A & A Manufacturing Electronics - Others Experts
Are you an A & A Manufacturing Electronics - Other Expert? Answer questions, earn points and help others
