Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Printer won't let me print or photo copy... On the screen it says " check paper size not sre how to do that...
When i get scanning that time he give me error code 105
Posted on Jul 29, 2010
  • 101 Answers
CHECK THE PAPER SIZE ENTERED IN THE PRINTING SOFTWARE IT MAY BE OUT OF RANGE TO UR REQUIRMENT.ALOSE CHECK THE ODEL AND USE PRESCRIBED PAPER
Posted on Jul 21, 2010
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
HP Photosmart C5280 wont select printing paper when making a phot
Update drives from Hewlet Packard web site Run the installation C/D which will create a shortcut on your Desk Top antomatically for HP Solutions and one for Photo Essentials( N.B ensure you have the latest Photo Essentials 3.5 )
Then
Click on Start
Select Pictures from menue
Select the photo you want to print
Click on Print
This frame will allow you to select the type of paper and size of print etc.that you want When you have done this Exit out
From your shortcut
Select Photo Essentials (3.5)
Import that photo from your Computer to Photo Essentials by clicking on the appropriate symbol
Then select Print ( at bottom of that screen) Finally select Single Print
And Enjoy
Good Luck
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
195 people viewed this question
old marine
old marine
