Question about Canon EOS 50D Digital Camera with 28-135mm lens
Err 20 turn off and on
Have turned on and off still says err 20
Canon EOS 50D
My camera shows "bussy" always and also appear the message " cannot format,what can I do to takle this problem?
Posted on Nov 23, 2010
I have err 99 any solution?
.1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99' message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99' message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99' message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99' with a different Canon lens attached, then the
camera should be serviced.
Jun 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
May 25, 2009 | Canon Cameras
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
camera body.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
ERROR CODE E63:20
sir E63 ERR is related to lens err ur camera lens unit dislocated or gears problum. this is easyly repairable
Dec 31, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Canon EOS 50D Digital Camera with 28-135mm lens Logo
334 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
