Question about Pool & Spa
I have a lazy xl spa heater light coming on massage system working but but hot water not circulating
When the bubbles are on the water blowing out of them is cold, you can not run bubbles and heat at the same time
Posted on Oct 19, 2010
Raypak model c-405b-en not heating. Flames coming on but hot water not circulating to pool.
check manual bypass by plumbing round plug the spring might be broken then water bypasses heater
Nov 23, 2015 | Raypak Pool & Spa
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
Heater will not come on; water is not circulating through heater
if no water is going through heater open return valve if you have a bypass only open half way see if that works or I need more info
Jun 09, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Nov 22, 2010 | Qca Spas Pool & Spa
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Hot tub no heater or pump heater light flashing
Thank you for posting your question here on Fixya.com.
Start with the pump. If it is bound up and not starting nothing else will work. Close off your valves and disconnect the pump unions. Once free, reach in with the pump unplugged and try to turn the impeller by hand. Will it turn? If not, you'll need to free it or get the pump repaired. Once the pump is working and water circulating your heater should start working.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 10, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
I have a hot water circulator when i turn on the cold water hot water comes out for about 30 seconds before the cold water will come out. What could be causing this?
This is could be because the system is set up to use the cold water line as the return to the HWH.
Hot water recirculation systems generally consist of a pump, an integrated electronic controller, and a zone valve. When the activation button is pushed, or when another type of control turns the system on, the pump starts recirculating cooled water that's been sitting in the hot water line and sends it back to the water heater through the cold water line.
If you would like..Google "hot water re-circulation theory"...it further explains this senario.
HTH,
Mike....
Dec 01, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Apr 20, 2009 | Pentair Mastertemp Heater
Pool & Spa Logo
157 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
