Question about AEG Washing Machines
Aeg 72630 won't spin
It won't spin - it will wash and pump out but will not go into fast spin
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Most likeley cause are worn out carbon brushes in the main motor. have you seen any error codes e52 relates to the motor brush problem. e20 is inefficent draining caused by blockage in the pump chamber acces in the plinth area/ or in hoses or drain connection
Posted on Jul 24, 2010
  • John Wilkinson Jul 24, 2010
    futher if you are trying to spin a small or awkward load like bath mats or jumper by themselves this machine wont spin if it cant balance the load. you have to add more items 2 or 3 small towels would make it spin
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Hi, I have an AEG 72630 Update machine, its been very noisy for a while on spin cycle but now is making a rattling noise & is leaving black spots on clothes, could it be bearings??
Yes this is the bearings, they have completely collapsed and the oil is leaking out onto your clothes. You will need a new tub rear and that is around £120 plus labour. Sorry its not better news.
Mar 07, 2011 | AEG Washing Machines
The pump is not working - i want to get the front off my AEG 72630 washing machine, so that i can remove the pump and clean it- how do i do this?
To remove the front panel, you first need to remove the Top COver / Worktop. It is fastened at the back. Remove or unclip it at the back and push it back and lift the Top off. After which, you will be able to remove all side panels and front panel.
Hope it helps :-)
* If you found this solution helpful, please vote positively.
Feb 19, 2011 | Washing Machines
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
Feb 12, 2010 | AEG Lavamat 72640 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Washing Machines Logo
584 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
