Question about Sony Ericsson W760i Cellular Phone
I can only use the upper keypad when the phone is slided down. Need help ASAP.
  • 101 Answers
Yes u can use it.before that unlock the keypad by pressing unlock and ok using upper
Posted on Jul 21, 2010
Cover keys are not working
Flex connector that connects upper and lower panel seems to be the problem and needs a replacement,due to strong sliding up and down mechanism that might cause cut off the flex or ribbon.parts and service are available in any mobile service shop near you.
If the mobile has the history of dropping the phone,this can be fix by inserting the flex properly and fit,this may lose contact during the incident.you can fix it alone by unscrewing 4 screw at the upper back panel,lift up the cover,remove side buttons then lift up the main board and check the slot and clips which the flex connector is inserted. as well as doing it on upper panel.
If the mobile accidentally fell into water,just do the same way you open,Particularly on upper panel which keypad is not working,might corrosion,stained exists and need to clean the keypad membrane and the keypad interface.
If you think this method looks difficult to do, just ask assistance to any mobile service shop near you...Good luck
Jun 28, 2011 | Sony Ericsson W910i Cellular Phone
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
Help I need to mute my keypad on my Samsung C3050 as it is driving me mad
psd4n.jpgThe buttons on the side that you see in the picture ^^^^ are the Keypad volume control, just slide your phone open and press them, up for loud, down for mute.
Feb 14, 2011 | Samsung C3050 Cell Phone
The center button to unlock when slide is closed is not working.
you should check your fiber (flex cable) and if ok, then the upper keypad board. those are the two major causes and if they are all fine, then replace the keypad IC.
Nov 02, 2010 | Nokia 5300 Grey Cellular Phone
Screen is distorted
hi :) screen distorted ?? for slide phone,the screen and inner upper keypad was control by a ribbon. if the ribbon spoil,will effect screen,upper keypad cant use,coming speaker cant hear. what u need to do better send for technician replace a new ribbon.
if my solution useful,please rank me.thank.
Jul 18, 2010 | Samsung SPH-m520 Cell Phone
When i slide up of my samsung j-700 mobile 3
j 700 open the camera please slide up problem
Jun 01, 2010 | Samsung J700 Cellular Phone
Samsung keypad locked
Samsung UpStage SPH-m620
UNLOCKING YOUR KEYPAD
theirs a button that you slide up and down. ... (you may try to push it but it wont work... you need to slide the button.) I had to go to my sprint store to figure this out.. :)
Jan 29, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Display problem in Nokia N80
It's a problem with the wiring that connects the upper part of the phone to its lower part when you slide it up. The wiring apparently gets damaged easily and you need to have it replaced, the wiring only, not the phone. This has also happened to me and I sent my phone to a certified Nokia Service Center. They replaced the faulty wiring but since my phone was still under warranty, they did not charge me anything. Hope your phone is still under warranty. Good luck.
Jun 13, 2008 | Nokia N80 Cellular Phone
6270 upper keypad not working
Inside belt(cable) problem. Change your cable then it works
May 12, 2008 | Nokia 6270 Cellular Phone
Sony Ericsson W760i Cellular Phone Logo
73 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
