Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GW703 OOB Switch Fault I've diagnosed a OOB (out of balance) switch fault with a GW703 washing machine from the error code 00101011. I've checked the switch and it moves freely and clicks when pushed in. I've checked the wiring and it appears to be plugged in. I have not as of yet removed the switch to check it closer. The machine is also level and the bias spring appears fine. Would this be an issue that is best resolved with a new OOB switch or is it an issue with the Motor Controller Module?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now the easiest way to check to see if the problem is your oob switch is to join the two wires that go to the switch with a small piece of wire so there is conductivity between them.This will bypass the switch and if you still have a problem then it could be your motor controller or your rotor position sensor.Please try the joining of the wires and see how you go.If it rectifies the fault then change the switch, if it does not rectify the fault then I can help you further when you reply back.Please turn the power off at the wall before you do this bypass.Make sure when you join the wires you tape up the joins with tape to stop them shorting out on something.When you have joined the wires try a cycle and see how it goes.Hope this helps.
Posted on Jul 22, 2010
  • 1 more comment
  • bjb125 Oct 11, 2010
    I was constantly having a problem with the OOB switch on our Fisher Paykel GWL10. Usually cleaning the switch with a electric contact cleaner worked fine, until now. We had a load of laundry to get done, so I tried your 'bypass' suggestion and machine worked fine. Is it necessary to change the switch or can I just eliminate it altogether and leave the bypass?
  • luisa_sgro Oct 12, 2010
    Hi just read your posting.I would recommend you change the switch as this switch will stop the machine jumping around if it goes out of balance.They are quite cheap but make sure you buy a switch that has the contacts ,NORMALLY OPEN AND NORMALLY CLOSED, as you will using the NORMALLY CLOSED CONTACTS.Hope this helps and please reply on how you got on or for further assistance.Looking forward to your reply.
  • thecoghlans Jul 22, 2011
    I had exactly the same problem so followed your advice and it worked. Thanks so much. Will now try and hunt down a replacement switch. Cheers.
I also had the same issue but the switch was fine after testing in diagnostic mode 4 (push tub to back right and 4th wash ligght should come on). After taking the top off, found that bias spring that connects from front left support rod to red spring bias clip on outer tub had come disconnected. Probably one big out of balance load knocked it off. Looks like it got a stretched a bit so ordered from searspartsdirect for $11 with shipping. Current one is still connected and no problems so far.
That spring aint much, but it keeps the outer tub from moving to the back right and triggering the out of balance sensor, which was causing machine to stop in the spin cycle. Everything else seems to be in good working order upon visual inspection. Both F&P washer and dryer have been easy to work with and repair so far (dryer had bad/squeaky pulley that needed replacement after 6 yrs).
Posted on Jun 03, 2012
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Hi. I have a fisher and paykel GW703 which has started displaying the error codes 00101011 then stops and beeps every second. this happens when it starts filling.I am assuming it means it is out of...
It is a problem with your out of balance switch. The primary source of problem is usually mechanical and they say to check the following. 1. check that the out of balance (OOB) switch is free to move. 2. Check that no harnesses are blocking switch movement. 3. Check that switch operates correctly when activated, Replace switch if suspect. 4. If the OOB micro switch shows signs of corrosion, replace the switch and fit a condensation kit to the console area.
Secondary source of problems can be the wiring. Check the harness to the switch and make sure that it is connected correctly. The terminals should be connected to the normally closed position. If the harness shows signs of corrosion then replace the harness. Hope this helps.
Aug 07, 2014 | Fisher and Paykel Washing Machines
43 error fisher paykel
Out of Balance Switch Fault Fault code #43
The out of balance switch is permanently activated or the harness to it is disconnected.
Nov 17, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel gw712 will not spin
That is fault code 43
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
disconnected.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Apr 06, 2013 | Fisher and Paykel WA37T26G Top Load Washer
We have a Fisher and Paykel washing machine model MW509NZ. it keeps going into error with Leds 3, 5, 7 and 8 illuminated and a beeping noise. What is the problem please.
Here is the info for 43
disconnected.
Action:
if suspect.
Action:
Aug 06, 2012 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel GW708U Smart Drive Excellence 7.5kg Washing Machine. What is fault code 43?
disconnected.
Action:
if suspect.
Action:
Jun 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fp excellence 7.5kg starts filling then stops, tries again a few times shorter each time and then errors with following led pattern: 00101011. We have levelled and tried over and over again, very...
Fault code 43
OOB switch error (out of balance)
CHeck Bowl Is Balanced Check Bias Spring is keeing bowl central
Most Likely Cause Corred terminals on Out Of balnce micro-switch
Jan 01, 2011 | Fisher and Paykel (IWL12)
What is code 43
Code 43 is Out Of Balance fault. Most probably because the OOB switch has failed (not uncommon) or the trigger arm has become jammed over the bowl.
The OOB mechanism is under the main motor controller module.
To access the controller and the OOB switch you have to remove the 2 screws at the rear of the facia. Fold the display panel forward and remove the larger screw which secures the controller. At this point you may be able to fold the controller to the rear without removing many (or any) of the connecting wires. This will expose the OOB switch. These switch contacts can become oxidised. If the switch won't 'click' it should be replaced. Test switch continuity with a multitester.
Make sure the replacement switch has the same function mode as the one you remove. (Some switch to 'ON' and some to 'OFF' )
I have described the most common cure for a code 43, but remember there are other reasons for the fault to be detected..
Good luck...Nomess
Sep 05, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 43
Error code 43 indicates that the washer is 'out of balance' . The switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The micro switch might be probably the faulty one. When replacing the switch make sure it's the same as the one coming off as they can be opposite function. Sometimes the oob arm below the oob switch can get jammed over the edge of the bowl and result in the same fault.
Thank you !!
Jun 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
I'm not exactly sure of the model, however it is code 43
43 error is the 'out of balance' fault code. The oob switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The microswitch is most probably faulty.or there is oxidation on the slide on connections. When replacing the switch make sure it's the same as the one coming off as they can be opposite function...Sometimes the oob arm below the oob swich can get jammed over the edge of the bowl and give the same fault...Check that first....Good luck....Nomess
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
978 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
