Question about Gateway MX6920 Notebook
Taking apart MX6920 for cleaning
My laptop undoubtedly has a lot of dust plugging up the heat sinks and vents. How can I take it apart to clean it without breaking anything?
  • Gateway Master
  • 13,433 Answers
Im uploading you a service manual for a gateway 600 notebook. Your laptop is similiar not the same model, but if your smart enought the manual will help you thought the process.
It covers the basics of takeing a laptop apart and puting it back together the same way.
you will most likely have to remove the keyboard, and the top cover of the laptop, don't force or rush anything.
http://ekse.x10hosting.com/Support/
Ones you take one laptop apart, you can take any laptop apart.
They are all very similiar.
If you need anything let me know.
Posted on Apr 22, 2008
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
Laptop crasc. no error report
Maybe it is overheating and it shuts down so that it does not damage the motherboard.
Three things that will cause a laptop to overheat.
1) Dust - Dust inside the computer, dust clogging the vents, dust around the fans, cpu and heat sink. Remedy - The best remedy is to take the laptop apart and blow the dust out with a can of compressed air. If you don't take it apart you could blow out the vents with a can of compressed air and it might work, but you will be blowing the dust inside.
2) A Fan not working. The laptop will have to be taken apart to replace the fan.
3) The Thermal Paste around the heat sink and cpu had dried up or is too thin to keep the unit cool. Take the laptop apart and apply a fresh coat of thermal paste around the cpu and heat sink.
One sure sign of overheating is that if you immediately try to power the laptop back up, it will not boot. But if you wait awhile and let it cool off then try to boot it up, you can boot successfully until it gets hot and shuts off.
You could also try a Cooling Pad that plugs into the usb port and the laptop sits on it. It has fans to keep the laptop cool. The pad can be purchased for under $20. Try Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type in the search box at the top: Laptop Cooling Pad. When the search results come back sort them by Price Low to High and you will see them starting at $5.99 or so.
I like the one below for $12.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1879782&CatId=3486
May 08, 2012 | Computers & Internet
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
May 29, 2011 | Toshiba Satellite X205-S9349 Notebook
My acer aspire turns itself of after about 30min of using
Usually,, something like this is caused by a heat problem.
Things that usually heat up in the laptop are:
- the CPU (check the fan, may have to take apart to really clean)
- the Video Card (this may have a fan but usually a heat-sink, also may be dirty and full of dust)
- the RAM (usually nothing much to do here)
- the Hard Drive (this may be the problem but check other things first)
I would check the following forum as they describe how to take it apart for cleaning and also refer to a "build up" of dust in this laptop model.
http://www.avforums.com/forums/laptops-netbooks-tablets/1057228-acer-aspire-7720-turns-off.html
Another thing would be to check the BIOS version and also check at what levels the alerts and actions are set.
Also, when using a laptop - do not cover the fan vents which may be underneath.
Good luck
Feb 27, 2011 | Acer Aspire 7720 Notebook
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 13, 2011 | Computers & Internet
My nv7802 overheats and shuts off,fan is running but the heat sink gets very hot
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Dec 30, 2010 | Gateway NV7802U Notebook
Gateway m675 fan runs almost constantly, and it's having an affect upon my hearing (due to an old injury). I've tried the simple things, like cleaning vents, or adding a laptop cooler/platform (on the...
I would suggest either taking the laptop in for service to have them remove the case an remove any dust build-up on the heat sinks.
If you're good with a screw-driver, you might try to do the cleaning yourself.
You can't really clean the air vents well without taking apart the laptop.
Dec 21, 2010 | Gateway M675 Notebook
Laptop heats up then shuts down cools down starts again does same thing again
That sounds like the cooling fan is either plugged up, or it is faulty, or the cooling fins for the CPU heat sink are plugged up with lint and dust. The cooling fan on that toshiba should be accessible through a cover panel under the pc notebook. Remove the cooling fan and use compressed air in a can to clean the cooling fan and the cooling fins to the CPU heat sink and be sure that the air intake vents for the cooling fan are also clean and free of any dust, dirt, or lint. Here are some images that are similar to help assist you, and let me know if you require any further assistance.
Sep 06, 2010 | Toshiba Satellite A135-S4527 Notebook
Auto shut down due over heat
Very Very Carefully disassemble the laptop, and clean out the processor fan, and any other "vent" looking things. Lots of times hair (especially pet), dust and other pollutants will clog these, or they may stop working all together, and need replaced.
Nov 19, 2009 | Sony VAIO GRZ660 Notebook
Gateway MX6920 Notebook Logo
417 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
