Question about Anchor Audio/PA Systems: Liberty Sound System Package Microphone
Cant get signal or sound on wireless speakers. Which Audio Socket on TV do I use Audio/visual input or RGB DVI or Audio outlets on AV TV recorder Humax 9300T TV is LG model26LB75
  • 313 Answers
You should be looking for the audio out socket from the tv as the signal is going out from the set to your speakers the other sockets are for input when connecting dvd or video into the tv. hope this helps ..A
Posted on Jul 21, 2010
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
Are you able to use the VIZIO 47" Class 1080p 480Hz SPS LED Backlit LCD HDTV as a computer monitor and use a wireless keyboard and mouse to browse on a pc through rgb and speaker jack?
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | Televison & Video
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
What type of audio jack rgb/dvi in on rear of lg 50ps3
the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
so LG diagram shows separate audio into Audio in RGB/DVI.
Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
The audio jack would only work with mono plug for audio in, to RGB.
Dec 08, 2009 | LG Televison & Video
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Hdmi to dvi
a DVI Connection does not transmit sound, so you will need a seperate audio cable. Have you changed the settings in the ps3 and your tv's input to HD signal or 720 DPI, do not choose 1080i or 1080P as DVI does not support those high settings.
Sep 05, 2007 | Sony Playstation 3 (PS3) Console
Anchor Audio/PA Systems: Liberty Sound System Package Microphone Logo
171 people viewed this question
Top Anchor Audio Players & Recorders Experts
Michial Gueffroy
old marine
old marine
Tom Chichester
Are you an Anchor Audio Player and Recorder Expert? Answer questions, earn points and help others
