If you are sure that the thermostats are both ok and the element has been replaced then the only other thing it can be is either a blockage or the timer that is at fault.
Hope this helps,
Testimonial: "You ae correct inwhat you say - Thermostats are ok , heating element had been replaced and I ave a timer on order so fingers crossed this will be the "
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas.
If one of the two thermal fuses are blown you will not
get heat. Thermal fuses blow (and are
not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow
through the machine. Check and make sure
your exhaust vent is not clogged. Clean
it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the
machine when it is turned on. If not you
have a blower problem.
The thermal fuses are located on the element casing. They each have two wires coming out of them. They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across. With a multimeter, check the continuity across the terminals. If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter. No continuity means the element is broken. Replace if necessary.
To check for a broken igniter, take out the old one and
look at it. If it looks broken or very
burned, replace it.
