Question about Irons
Spare Filters required for water supply unit for Model No DSG2
  • Irons Master
  • 6,993 Answers
you can get the spare filters online from the below link:
http://www.waterfiltersonline.com/
Good luck.
Posted on Jul 21, 2010
Morphy Richards iron smells bad.
Do you use distilled water in your iron. The filters may have bacteria on them, especially if the filter does not get very hot. Bacteria thrives in dark, wet environments. The bacteria has moved away from the filter into the iron, so changing filters would not help much for very long. I would buy a new iron that does not use filters and only use distilled water in it. Distilled water stops mineral deposits from forming inside the iron.
Dec 05, 2015 | Morphy Richards Irons
It will not steam. We put in a solution of vinegar and 2 parts water from a pitcher that filters water. Will this be considered distilled water or is distilled water critical?
Distilled water and filtered water are not the same. Distilled water is water that has been boiled then condensed so that most of the impurities that cause water hardness (Sodium, Calcium, etc.) have been removed. Filtering does not remove these which is why your iron will clog up much quicker. Same applies to your car battery, distilled water only! To clean it mix "Lime Away" with water about 1/4 cup with water every 6 months or so, then rinse with clean water a few times to get rid of the green color, steam until it comes out clear again..
Mar 10, 2015 | Rowenta IS9100 1550W Precision Valet...
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
Russel hobbs 14546
if you want to open it up the screws are hidden, and you need to carefully prise off both the blue filling funnel at the rear, and the surround for the water spray nozzle at the front (knife or thin blade driver). Then you will meet a mix of pozi and anti-tamper screws needing a fork driver. The power supply for the blue LEDs is wrapped in a disconcerting gold coloured (mylar) pouch, and does not affect operation. The thermostat and the supply to the red neon light are all in the base plate with the element, the overheat fuse is in a "sausage" of sleeving P clipped to the baseplate. In our case this fuse had gone open circuit, and temporarily shorting this out restored normal operation until a spare could be located.
Apr 11, 2013 | Russell Hobbs Irons
What type water required for steamer model GS5BK
If you do not have a water softner, all steam generating machines require some type
filtering system to prevent hard water build up, best to use is distilled water. good luck!
Jul 27, 2011 | Conair Compact Garment Steamer Iron
Where can I obtain spare anti scale filters fro the Breville Steam Generator IIN 195?
http://www.argosspares.co.uk/cgi-bin/product.pl?PID=1904605&brand=breville&model=&part=
I had to ring Breville direct as was having trouble finding them and they said as it was purchased from Argos they will have them - so went to contact argos & found this website - hope this helps
Oct 15, 2010 | Breville Irons
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
Irons Logo
21 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
